Clicking noise from tranny... throw out bearing?
Old Feb 1, 2005 | 10:20 AM
Emshhh's Avatar
Default Clicking noise from tranny... throw out bearing?
hey guys, i did a search on "noise from a tranny" and all i got from it is it could be a throw out bearing. But my situation seems different then the symptoms from a throw out bearing.
People described it as a "whirling noise" when clutch was engaged.. well mines a "cgrkejlk sldkfjiske dkjhekjl clikck dkej" noise when the clutch petal is depressed... ALSO, sometimes as a stop, even with the clutch petal depressed, i cant get it into any gear.
::::Video so you can hear the sound:::::
http://www.we-todd-did-racing....DE%3D
***right click save as****
got any ideas?
It's deffenetly coming from the tranny.
Old Feb 1, 2005 | 10:31 AM
JDEM1's Avatar
Default Re: Clicking noise from tranny... throw out bearing? (iGfrequency)
well, I've had this problem with my past 3 clutches... it's not a aiohjcpoudsopica noise.. it sounds like a giant cricket chirping and squeaking, it's driving me insane, and people tell me it's the throwout bearing..
Old Feb 1, 2005 | 10:34 AM
snatch's Avatar
Sounds like it could be the clutch itself, or maybe a really bad bearing in the tranny. Two questions though:
1. Does it vary with speed (ie: click faster or slower)?
2. Can you shift it into gears with the car off?
Old Feb 1, 2005 | 03:29 PM
Emshhh's Avatar
Default Re: Clicking noise from tranny... throw out bearing? (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like it could be the clutch itself, or maybe a really bad bearing in the tranny. Two questions though:
2. Can you shift it into gears with the car off?</TD></TR></TABLE>
1. not sure because i dont really hold my clutch in when im moving.
2. yes i can. 80% sure i can i'll check again
Old Feb 1, 2005 | 03:36 PM
nub.96ek's Avatar
Just bust it opoen and replace the throwout and pilot bearing... also could be the fingers on ur pressure plate are warped or or worn.
Old Feb 1, 2005 | 05:17 PM
Emshhh's Avatar
Default Re: Clicking noise from tranny... throw out bearing? (nub.96ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek &raquo;</TD></TR><TR><TD CLASS="quote">Just bust it opoen and replace the throwout and pilot bearing... also could be the fingers on ur pressure plate are warped or or worn.</TD></TR></TABLE>
does anything specific cause that?
i guess it's time for a aftermarket upgraded clutch :D
Old Feb 2, 2005 | 04:13 AM
ironlung78's Avatar
i've actually seen where the "fingers" on the pressure plate actually break off and thats what you hear rattling around near your flywheel
Old Feb 2, 2005 | 04:43 AM
snatch's Avatar
Default Re: Clicking noise from tranny... throw out bearing? (sidesi)
I think it's your clutch. Maybe something to do with the pressure plate.
Old Feb 2, 2005 | 06:41 AM
runs11's's Avatar
Just buy an act clutch kit it comes with everythign new pressure plat new throw out bearing new clutch and you'll be fine it might be a bad pressure plate but it sounds like the throw out bearing cause when mine when bad it sounded lik valve tap but when i pressed the clutch in it stopped so idk.
Old Feb 2, 2005 | 06:46 AM
freakin_eLRoD's Avatar
could be the input shaft bearing, but then again thats more of a whirring noise. only one way to find out, pull the tranny and inspect
Old Feb 2, 2005 | 05:58 PM
Emshhh's Avatar
Default Re: Clicking noise from tranny... throw out bearing? (powerBan.est1990)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerBan.est1990 &raquo;</TD></TR><TR><TD CLASS="quote">could be the input shaft bearing, but then again thats more of a whirring noise. only one way to find out, pull the tranny and inspect</TD></TR></TABLE>
i have no beater car, so any thing like that would have to be for a 100% reason. tonight driving home my gears were almost "sticking" in. like the sycros wouldnt release for a 2nd. My guess is the clutch isnt releasing from the flywheel? that could also explain when my car wont go INTO gear when im stoped.
... im pretty sure it's not a throw out bearing because it STOPS when i let the clutch pedal out.. opposite of a throw out bearing symptom.
Old Feb 2, 2005 | 11:10 PM
JDEM1's Avatar
eh?.. When I press the clutch pedal down even only past the freeplay part of the clutch.. the noise will stop.. but if it's full engaged or disengaged with the pedal all the way up, the noise drives me insane..
RG400SmartTowel
Transmission & Drivetrain
Oct 22, 2009 06:18 PM
CPR
Dec 14, 2005 10:26 PM
4gnhatch
Jun 24, 2005 06:53 PM
GSRacer1
May 31, 2004 11:33 PM
sohcvtec66
Dec 12, 2003 12:40 AM
