84-87 CRX questions...
Old Feb 1, 2005 | 09:59 AM
TurboFryBox's Avatar
Default 84-87 CRX questions...
Ok I did a search, didn't find anything and am hoping someone can direct me to the right place. I'm not up on my 84-87 CRX's...A friend has a 87 si, he wants to swap a head from a newer 88-91 D16. Will it work? I know the exhaust ports are different but I dont know if the internals are too much different, anyone have any thoughts?
Thanks,
Travis
Old Feb 1, 2005 | 10:27 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: 84-87 CRX questions... (TurboFryBox)
red pepper racing, that is all you need
stan
Old Feb 1, 2005 | 10:48 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: 84-87 CRX questions... (Stan D)
^^^^What he said. http://www.redpepperracing.com Sorry but no 88+ head bolts onto the 84-87 blocks. One head bolt hole doesn't line up, as well as other problems. The best/easiest swap is a D16A1 out of an 86-89 integra along with the tranny/ecu/axles/front suspension/etc. Read the FAQ over at redpepper and it should tell you everything you need to know.
Old Feb 1, 2005 | 11:29 AM
Kwicko's Avatar
Default Re: 84-87 CRX questions... (tjbizzo)
And the easiest of the easy swaps is the '86-'87 Integra D16A1, for one simple reason: it used the same vacuum advance system on the distributor that the '85-'87 CRX Si did. The '88-'89 Integras went to an electronic advance, which is still a swappable engine, but it takes more time and wiring.
Redpepper is THE source for excellent 1G CRX/3G Civic info. It's my first stop when I've got questions about my '87 CRX Si, and they've never failed me.
Mike
Old Feb 1, 2005 | 11:40 AM
Default Re: 84-87 CRX questions... (Kwicko)
Sweet, thanks I knew there were resources out there, and i was pretty sure the swap wouldnt work I just couldn't find a yea or nea. Off to redpepper I go.
Thanks again,
Travis
Old Feb 1, 2005 | 01:04 PM
MeRexZC's Avatar
I have an engine for you. Look @ my Signature. really cheap.
Old Feb 1, 2005 | 01:36 PM
tjbizzo's Avatar
Default Re: 84-87 CRX questions... (MeRexZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeRexZC &raquo;</TD></TR><TR><TD CLASS="quote">I have an engine for you. Look @ my Signature. really cheap.</TD></TR></TABLE>Price?
Old Feb 1, 2005 | 02:02 PM
MeRexZC's Avatar
only 150.00 with 4-1 headrs, and new clutch,flywheel, pressure plate. includes tranny. 5Spd. I'm just making it Cheap so shipment won't kill you. Plus i have no use for it. pulled out of a car about three days ago.
C.J.F
Apr 16, 2010 08:47 AM
socalvw56
Classic Hondas
Aug 30, 2007 10:00 AM
crxlilmikey
Mar 3, 2005 11:40 AM
silverbulletgsr
Nov 10, 2004 06:40 AM
civicflow
Jul 21, 2004 07:50 PM
