B16A Vs B16B CrankShaft ??
Old Feb 1, 2005 | 01:00 AM
Ratman's Avatar
Default B16A Vs B16B CrankShaft ??
Spoon have a stroker kit for the B16B, will it fit the B16A ??
Modified by Ratman at 11:38 AM 2/2/2005
Old Feb 1, 2005 | 02:00 AM
anothersickhatch's Avatar
Default Re: B16A Vs B16B CrankShaft ?? (Ratman)
i believe the specs and stroke are the same...i dont see how they could be any different.
if the bore is the same and they are both 1.6 liter, than they are the same.
Old Feb 1, 2005 | 02:16 AM
THEUSED's Avatar
NO it will not, the B16B has a taller deck height than a B16A, a B16B block is just a destroked B18C5 block
Old Feb 1, 2005 | 03:16 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: (THEUSED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">NO it will not, the B16B has a taller deck height than a B16A, a B16B block is just a destroked B18C5 block</TD></TR></TABLE>
correct. to back the above poster up, the timing belt is the same part # for both the b16b and the b18c, wheras the b16a belt is a different part # (shorter)
Old Feb 1, 2005 | 06:04 AM
james p.'s Avatar
Just cause they have the same displacement it doesn't mean they're alike. R/S is totally different in the B16B than the B16A.
Old Feb 1, 2005 | 11:47 AM
Default Re: (james p.)
i was referring to the crankshaft similarities, not if the stroker kit will fit or not. my bad.
he asked any differences in the crankshaft in the first question.
Old Feb 1, 2005 | 12:16 PM
james p.'s Avatar
Default Re: (anothersickhatch)
same stroke 77.4mm
different weight and balance
Old Feb 2, 2005 | 12:02 AM
Ratman's Avatar
hmm, so it is not posible to take the GSR Crank,rods and pistons,
and mount them in a B16A2.. damit
then the primary reson for the diffrence must be the length of the rods,
becaus the stroke is the same in B16A2 and B16B, but yes, it seems the
deck height is not the same..
this must alsow mean that the B16B Block, is the same as B18C blocks
Jdmb16sir2
10
Apr 10, 2007 06:46 PM
mkinpwrat12g's
Nov 15, 2006 07:54 AM
gulftiresinc
12
Aug 14, 2004 10:39 PM
EF_LSVtec
Aug 28, 2003 07:10 PM
Unsung
Jun 16, 2003 05:38 PM
