oil filter seal blowing on b20 vtec
Old Jan 31, 2005 | 09:36 PM
fabs's Avatar
Default oil filter seal blowing on b20 vtec
i just built the motor with 12.5 comp. the motor has good oil pressure. idle at 30psi and around 90 at open throttle. now the seal breaks at idle. i tried the s2000 filter, purolater and fram, all with the same result.
i made sure the old gasket was off the block before the new filter came on.
i am really stumped o this one guys.
thanx
fabs
Old Feb 1, 2005 | 10:27 PM
Mike K's Avatar
Default Re: oil filter seal blowing on b20 vtec (fabs)
just try an oem skinny one, and torque it to spec. there's no reason it should blow.. unless you shimmed the **** outta your oil pump for more pressure. it'd probably be a good idea to hook up an oil pressure gauge and see what it's hitting.
Old Feb 1, 2005 | 10:34 PM
fabs's Avatar
Default Re: oil filter seal blowing on b20 vtec (Mike K)
i have the oil press gauge. its 30 at idle and 95 on full throttle. i am gonna check the relief valve on the oil pump to make sure it not stuck.
Old Feb 3, 2005 | 12:30 PM
zccr-xsi's Avatar
wow aint never seen that happen before hum? u did put lil bit of oil on the ring n/m doubt that would work yea i would try to get skinnyer one and tq. it. i should be fine
Old Feb 3, 2005 | 09:45 PM
fabs's Avatar
Default Re: oil filter seal blowing on b20 vtec (vteckillenzc)
i just tried that and no luck. i am going to replace the whole pump to see what happens. and to add to the drama i drove my car for the first time in about 2 weeks, and some body hit me from the side. that sucked but at least i get a fresh paint job.
Old Feb 4, 2005 | 04:45 PM
zccr-xsi's Avatar
danm man that sucks big time i got fresh paint job too
hum?is the place where the oil filter goes drity something might be making it leaking and letting oil out.i dont know?????lol
Old Feb 4, 2005 | 04:46 PM
zccr-xsi's Avatar
try useing oem one for b20 it make work just a thought...
Old Feb 4, 2005 | 05:11 PM
Chiovnidca's Avatar
Is the filter seating all the way down? 90 psi shouldn't be a problem.
Old Feb 4, 2005 | 06:40 PM
fabs's Avatar
Default Re: oil filter seal blowing on b20 vtec (Chiovnidca)
i tried the stock one but no luck. im just gonna put a b16 oil pump that i have laying around. i hope that works. now i have to fix it this week so i can take the car to the body shop.
any more opinion guys.
thanx
fabio
Old Feb 4, 2005 | 07:33 PM
zccr-xsi's Avatar
what kinda pressue u getting damn sounds like it to high?
Maiyen
13
Dec 26, 2017 04:20 AM
patrick4588
Jul 27, 2008 12:02 PM
epclean3
Jul 1, 2007 05:18 PM
tim120
Sep 7, 2006 04:55 PM
Excelerate
Nov 2, 2003 11:45 PM
