Popping The Clutch?, Causes?
Old Jan 31, 2005 | 04:35 PM
atli126's Avatar
Default Popping The Clutch?, Causes?
what causes this, i have had numerous problems with my new car, and this is killing me, i just replaced the starter, and my wiring was good, battery was new, starter is new also, and nothing would work except when we rolled it back outta my driveway and i popped the clutch and she started right up , i knew it had to be something retarded, bc everything was working right, but something was wrong
thanks
bret
i am thinking this is the ignition switch but im not sure?!
Old Jan 31, 2005 | 04:40 PM
dr_latino999's Avatar
Default Re: Popping The Clutch?, Causes? (atli126)
So it's not starting unless you role it? If that is the case, get on your knees and push the clutch switch with your finger and have someone or yourself with your free hand turn the key. If the car turns on you are having issues with the clutch pedal contacting the switch.
Old Jan 31, 2005 | 05:31 PM
Kwicko's Avatar
Default Re: Popping The Clutch?, Causes? (dr_latino999)
Have you checked all your grounds and your battery cables? ALL of them? Check them again. Clean them with a wire brush, and see if that helps anything. Also, you state that the starter is new; did the problem happen immediately after you put the new starter in? Has that starter EVER started the car? Do you have your old starter handy? It's possible that you just got a crap starter, even if it's new or remanufactured. Not common, but POSSIBLE.
I'd look at the little stuff first, though. As mentioned above, check the clutch switch and make sure that it's working properly (because it's free to check that, and easier than pulling the starter out). Also, fiddle with the ignition switch. I've seen them go bad, but I've never seen one that was good one day and completely gone the next. If the ignition switch is going out, you should still be able to start the car with it by holding it in a different position while you crank the car. For example, I usually end up pushing down on the key while I'm cranking the car. If my car isn't cranking or doing anything at all with the key in the start position, I'd try pushing up or up and forward while cranking it, to see if that gets me a good contact inside the switch. Again, it's free to try it.
Hope this helps,
Mike
Old Feb 1, 2005 | 03:11 PM
atli126's Avatar
Default Re: Popping The Clutch?, Causes? (Kwicko)
ok i dont have the clutch switch bc it is rhd, and im really leaning towards the ignition switch, bc someone told me that theirs did that and just got worse over time, until it did go out, but we have 12.5 volts at all contacts
thanks for the help
Old Feb 1, 2005 | 03:57 PM
the-pepsi-man's Avatar
clutch switch.... mine starts without touching the clutch lol
Old Feb 1, 2005 | 06:53 PM
1gEF-8's Avatar
have 12 volts at starter signal wire?
Old Feb 1, 2005 | 08:46 PM
ridexstraight's Avatar
Default Re: Popping The Clutch?, Causes? (1gEF-8)
my rex starts with no clutch is there ne pro/cons to not using clutch to start?
Old Feb 3, 2005 | 07:17 PM
supercreed2002's Avatar
Default Re: Popping The Clutch?, Causes? (ridexstraight)
A con would be that you forget that you left it in gear! lol
Caleb
Old Feb 6, 2005 | 09:31 PM
Default Re: Popping The Clutch?, Causes? (supercreed2002)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">A con would be that you forget that you left it in gear! lol
Caleb</TD></TR></TABLE>
OMFG i hate when my dad does it.... my parenyts only have one car. so my dad wants to borrow mine to go buy cigarettes or something. I HATE WHEN HE BORROWS MY CAR!!! but he always leaves it in gear... i dont. so i try to start it and it almost jumps through the garage door.... ***!!!
Old Feb 6, 2005 | 10:32 PM
Default Re: Popping The Clutch?, Causes? (the-pepsi-man)
well yea, , , hahahaa,,, but theres not pros or cins to clutch starten or not!??
Old Feb 6, 2005 | 11:15 PM
ecovillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridexstraight &raquo;</TD></TR><TR><TD CLASS="quote">
unless youve disabled the clutchlock, dont you have to put the clutch in to start it? so how would "starting in gear" be an issue? i always park in (first) gear. when im ready to go somewhere, i put the clutch in, turn it on, and go. no jumping issues or anything...
also id like to know the pros and cons of parking in gear!
Old Feb 7, 2005 | 09:19 AM
Default Re: Popping The Clutch?, Causes? (ecovillain)
If you disable the safety-switch, your car will move forwards when you start your car with it in gear! That's why they added this feature...
Caleb
Old Feb 7, 2005 | 10:30 AM
xtrafastcivic's Avatar
main relay can also cause this..
Old Feb 16, 2005 | 02:44 PM
atli126's Avatar
Default Re: Popping The Clutch?, Causes? (XtraFastCRX)
grounding problem got it fixed thanks for all the help, ground from battery to tranny, dumb mechanic ?!
Old Feb 16, 2005 | 04:17 PM
TEAM HATCH-N-IT 90's Avatar
check the dizzy cap i had won that it would ark but once you rolled or pushed it would start right up.
deucedeuceEK
Jul 21, 2015 10:32 AM
dannycraq
24
Sep 20, 2014 05:07 PM
viera
Sep 18, 2011 08:02 PM
94eg!
Jan 7, 2011 07:05 PM
atli126
Jan 12, 2005 08:47 AM
