washing rings...
Old Jan 31, 2005 | 02:42 PM
GDM Z28's Avatar
Default washing rings...
i know if you run rich you can wash all the oil off the cyl. walls which is called "washing the rings". when that happens what exactly happens to the motor? does it hurt all the rings? will that cause low comp.? also why dont you hear it happening to older engines just brand new ones. TIA
Old Jan 31, 2005 | 09:05 PM
PrettyLude's Avatar
you will start to lose copmression due to the rings not working to its full potential
Old Feb 1, 2005 | 04:29 AM
GDM Z28's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">you will start to lose copmression due to the rings not working to its full potential
so u always loose comp.?
Old Feb 2, 2005 | 04:07 AM
shauniewalnuts's Avatar
Default Re: (civicflnum1)
you will loose the seal with the rings and the cylinder walls... so yes a compression drop. you can get a teaspoon of oil and drop it thought the spark plug hole and try to regain comp. Maybe because older engines are all ready running and new engine you have to try to get them to start hah i dunno
Old Feb 2, 2005 | 07:56 PM
sickerhatch's Avatar
Default Re: (shaun311)
bump i wanna know to
Old Feb 3, 2005 | 04:59 AM
NJIN BUILDR's Avatar
Default Re: (sickerhatch)
What do you want to know that hasn't already been answered.
Glenn
Old Feb 3, 2005 | 08:49 AM
mmuller's Avatar
Mad Scientist
since there is no oil on the cyl. walls the rings will sand themselves against the wall. soon creating a smooth surface(rings and cyl. wall) thus no longer having anything to seal the combustion process with.
you can simply tell by looking at the cyl. walls, the crosshatch would be gone.
92civichbor
10
Aug 5, 2008 11:09 AM
EKtypeRhaTcH
26
Feb 21, 2005 09:23 AM
GDM Z28
Feb 1, 2005 04:33 PM
oryanh
Aug 19, 2003 04:32 AM
chinhead1228
Jun 17, 2003 09:38 PM
