anyone ?????
Old Jan 31, 2005 | 11:20 AM
spacin's Avatar
Default anyone ?????
https://honda-tech.com/zerothread?id=1133547
i think maybe its the dizzy but how the **** can you tell if i am getting spark or not??
Old Jan 31, 2005 | 05:58 PM
S2KBAR's Avatar
Default Re: anyone ????? (spacin)
Simple, just take off one of the spark cables from your distributor, then grab a nicely insulated screwdriver and put it near the hole where the cable goes. Ask someone to give the car ignition. If you see or hear the current flow from the distributor to the screwdriver then you have spark.
Old Feb 1, 2005 | 11:54 AM
spacin's Avatar
Default Re: anyone ????? (B16 Turbo Del Sol)
man cold start sucks *** same thing this morning
crank crank crank crank sputter crank crank crank sputter spit .......etc
try again
sputter crank crank sputter .... start smmmoookkkkeeee lots o gas in chambers
i'm gonna change the plugs and wires and rotor maybe that'll help
Old Feb 1, 2005 | 12:06 PM
SOHC4life 96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16 Turbo Del Sol &raquo;</TD></TR><TR><TD CLASS="quote">Simple, just take off one of the spark cables from your distributor, then grab a nicely insulated screwdriver and put it near the hole where the cable goes. Ask someone to give the car ignition. If you see or hear the current flow from the distributor to the screwdriver then you have spark.</TD></TR></TABLE>
And then you can do it the smart way and just pull the plug stick it back in the wire and put it on the valve cover, have someone crank the car and look for a spark. But if you feel like getting shocked.....knock yourself out.
Preludelearner
Mar 26, 2015 07:54 PM
HpreludeH
Dec 23, 2013 04:56 PM
85_305
49
Jan 15, 2009 05:42 PM
johnzm
Jan 24, 2005 05:28 PM
