B16A2 and B16B
Re: B16A2 and B16B (Slimasov)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slimasov »</TD></TR><TR><TD CLASS="quote">Excuse for my English, I have mixed, it is necessary to put crankshaft b16b in the engine b16a2. it really? </TD></TR></TABLE>
no, its not necessary to use the b16b crankshaft in the b16a2.
thats nice that you can speak and write another language
i beleive they are the same, the difference between the b16a and b16b is the head mostly aka, cams, size of ports, et cetera
Re: B16A2 and B16B (Soccerking3000)
Distinction only in a head means crankshaft identical?
Where it is possible to looking parameters of shaft on the Internet??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slimasov »</TD></TR><TR><TD CLASS="quote">Distinction only in a head means crankshaft identical?
Where it is possible to looking parameters of shaft on the Internet?? </TD></TR></TABLE>
i don't know any site's, but i think they use the same crankshaft.
Re: B16A2 and B16B (moreno)
they both have the same stroke, but the crank shafts are most certainly not the same.
more counter wieghts on the civic R, just like integra R
Re: B16A2 and B16B (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious »</TD></TR><TR><TD CLASS="quote">they both have the same stroke, but the crank shafts are most certainly not the same.
more counter wieghts on the civic R, just like integra R </TD></TR></TABLE>
now i know
is it the same as an itr?
now i know
Both cams vary significantly, specially in the intake side. According to Spoon's race engineers, the valve springs need not be swapped out for the Type-R dual springs if (and only if) the rev-limiter is not raised above that of stock. But it would be rather stupid to put CTR cams and not raise the rev limiter, impeding their optimum engine speed range to be reached.
Consider upgradign your valvesprings and retainers if you plan of revving over 8200.
It's a good idea to upgrade the valvesprings w/ these cams anyway.
Cheers to Moscow (vodka, of course )
are we talking about CRANKshafts or CAMshafts?
for the CRANKshaft I say no (although not sure - bad headache, can't be bothered to search and verify)
for the CAMshaft it's a definite YES
Re: (james p.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by james p. »</TD></TR><TR><TD CLASS="quote">are we talking about CRANKshafts or CAMshafts?
for the CRANKshaft I say no (although not sure - </TD></TR></TABLE>
dont post up with BS if you dont know what your talking about... the orginal poster is confused as it is...
the answer is YES for both
Re: (R you serious)
https://honda-tech.com/zerothread?id=367026
did a search, R/S is totally different between B16B (about 1.84:1) and B16A (1.74:1) and the stroke of the two cranks is the SAME (77.4mm) but the crank of the B16B is heavier and differently balanced. If that helps any.
