Custom DIY lower Tie Bar.
Old Jan 31, 2005 | 10:22 AM
racer_X_123's Avatar
Default Custom DIY lower Tie Bar.
This is my DIY lower tie bar. It took me about 3 hours to build. It attaches to the 2 holes above the lower control arm bolts. Many think that ground clearance will be a problem but it is not. Let me know what you think.
Overall view of the bar.
The plate that the bar is attached to the car with.
Old Jan 31, 2005 | 12:38 PM
CRXDrew's Avatar
It does look real low. Why not make it straighter, shorter, (stronger maybe)?
Old Jan 31, 2005 | 04:38 PM
Bakeoff's Avatar
Default Re: (CRXDrew)
you hit ANYTHING and your subframe is FUCT!
Old Jan 31, 2005 | 04:54 PM
xerox445's Avatar
Default Re: (Bakeoff)
what kind of metal is that made out of!!??? looks liek ******* pig iron or someshit dude...lol
thats going to suck when you hit a bump...
Old Jan 31, 2005 | 07:59 PM
jedubz's Avatar
I'm utterly confused as to what you were thinking.
Old Jan 31, 2005 | 08:05 PM
DOHCter's Avatar
not to sound like a hater or anything, but that looks like ****... my .02
Old Jan 31, 2005 | 08:07 PM
@ries's Avatar
Default Re: Custom DIY lower Tie Bar. (racer_X_123)
that seriously looks dangerous.
Old Jan 31, 2005 | 08:13 PM
CRXDrew's Avatar
Damn guys.... I was trying to be nice.
Old Jan 31, 2005 | 08:20 PM
sleepingEg8's Avatar
Default Re: (DOHCter)
Well Im gonna go ahead and give the guy props for making his own **** and not buying it. But I will also say sand the dang thing and paint it up and call it a day. It may need to be shortened so it wont touch the ground.
Not to thread jack or anything... but here is one that I fabbed up for a friend. It can be made VERY inexpensively... Hit me up if you want any help or suggestions.
Its amazing how so many people can't even find one good thing to say... Didn't your mother ever tell you... If you don' t have anything nice to say, don't say anything at all!!!!!
Good job and don't get discouraged!!!
Old Jan 31, 2005 | 08:26 PM
ophdehEEEzy's Avatar
Default Re: (sleepingEg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingEg8 &raquo;</TD></TR><TR><TD CLASS="quote">Well Im gonna go ahead and give the guy props for making his own **** and not buying it. But I will also say sand the dang thing and paint it up and call it a day. It may need to be shortened so it wont touch the ground.
Good job and don't get discouraged!!! </TD></TR></TABLE>
That car looks tight. Isn't that ophdeheezy's ride? Nice setup under there!
The 'DJ-Spec' product line is lookin hot!
Modified by Jems at 9:57 PM 1/31/2005
Old Jan 31, 2005 | 09:03 PM
magnet's Avatar
Remember that the intent is to tie the inner ends of the lower control arms together. Running the bar directly across will make it more effective, lighter, and will reduce any ground clearance issues.
Old Jan 31, 2005 | 09:24 PM
Miracle_X_Bar's Avatar
Default Re: Custom DIY lower Tie Bar. (@ries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries &raquo;</TD></TR><TR><TD CLASS="quote">that seriously looks dangerous. </TD></TR></TABLE>
damn..that thing looks like it was found in the ocean with the Titanic!!
Old Jan 31, 2005 | 09:30 PM
sporkcrx's Avatar
Default Re: Custom DIY lower Tie Bar. (Miracle_X_Bar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miracle_X_Bar &raquo;</TD></TR><TR><TD CLASS="quote">
damn..that thing looks like it was found in the ocean with the Titanic!!</TD></TR></TABLE>
hahaha, I'm sorry but that is funny!
Old Feb 1, 2005 | 09:02 AM
ProstockH22crx's Avatar
Same thing I was thinking... but for the effort
Old Feb 1, 2005 | 09:16 AM
3.3.3's Avatar
Default Re: Custom DIY lower Tie Bar. (ek four)
rust is the new gunmetal
Old Feb 1, 2005 | 09:19 AM
3.3.3's Avatar
that tie bar would compliment my hood locks. dont you think?
Old Feb 1, 2005 | 09:53 AM
js2k01's Avatar
Default Re: Custom DIY lower Tie Bar. (333+)
Damn. I has people go to far with ****. but damn he took it to far. Good job.OWND
Old Feb 1, 2005 | 10:16 AM
n1div's Avatar
Old Feb 1, 2005 | 12:27 PM
Guess I won't try to build anything anymore since it is apparent that I should just buy everything. So much for trying...
Old Feb 1, 2005 | 12:46 PM
Chronicsinners's Avatar
One thing that maybe you didnt realize, is that those are the holes for a Rear sway bar, a much more effective modification to the suspension.
As for your fab, just try and do a straight bar for the lca bolts. And this time take your time after test fitting it, and finish it properly. (Sand, Prime, paint)
Old Feb 1, 2005 | 12:48 PM
@ries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racer_X_123 &raquo;</TD></TR><TR><TD CLASS="quote">Guess I won't try to build anything anymore since it is apparent that I should just buy everything. So much for trying... </TD></TR></TABLE>naw man. you can't go out like that. just start over.... back to the drawing board.
Old Feb 1, 2005 | 12:53 PM
Yeah true...actually it is back to the drawing board i just bought a set of sway bas and that bar will be in the way, so when i get the new one made i will paintit and will post some pics up if you guys want. Thanks for all the input and ideas everyone gave me. If there are any more ideas out there let me know...Those hood locks are kinda growing on me...
Old Feb 1, 2005 | 03:54 PM
L-CON1's Avatar
dont give up! practice,practice,practice and you will get it soon enouph...
i am in no way trying to sound bad but next time dont post it on here without thinking really hard what the outcome will be. i give you much respect for attempting to build this yourelf and posting it. pm me and i will help you out a little then after you do your next one maybe you will get a better response.
Old Feb 1, 2005 | 04:05 PM
egizzle8
Guest
Posts: n/a
Default Re: Custom DIY lower Tie Bar. (L-CON1)
It just that it hangs really low and would be really easier to catch it on something and would rip off your subframe it you made contact with it. just get rid of the two bars on the sides that put it down closer to the ground and just make it straight across.
Old Mar 29, 2005 | 06:51 AM
jmildoc's Avatar
Default Re: Custom DIY lower Tie Bar. (egizzle8)
WHAT EXACTLY IS THAT THING GOING TO DO EXCEPT SCRAPE,MAKE IT STRAIGHT ACROSS MAN.
