Engine Knocking....leaking coolant
Old Jan 31, 2005 | 10:05 AM
GSR_Jamee's Avatar
Default Engine Knocking....leaking coolant
before anyone chews me out on this, i did a search...but all it says 'check for leaks, might need a new radiator'. im tryna get a more definte answer...
ok, so ive had this car for 2 weeks...no problem except for the brakes. then last night after i picked up my man, we smelled something really sweet, we knew it was coolant. so we looked and a lilttle leaked out. we also notice my engine was knocking. it was kinda dark...so i jus put a rag under the leak and then we went to bed. i wake up this morning to find the rag soaked, and coolant all over my garage floor. so i start her up...no leaks while shes running, doesnt over heat, but she idles funny. so when i turn her off she knocks again. it might either be a blown head gasket, or i might need a new radiator. can someone claify this more for me???
Old Jan 31, 2005 | 10:41 AM
GSR_Jamee's Avatar
Default Re: Engine Knocking....leaking coolant (GSR_Jamee)
anyone...???
Old Jan 31, 2005 | 11:02 AM
Slain's Avatar
check your oil to see if there is a milky substance ( headgasket failure) might want to do a pressure test on the radiator.
Old Jan 31, 2005 | 01:52 PM
GSR_Jamee's Avatar
Default Re: (Slain)
hMm..ill do that. thanks for yer help...anyone with any other suggestions?
Old Jan 31, 2005 | 02:10 PM
skunked's Avatar
Default Re: (GSR_Jamee)
sounds like a headgasket.......
Where is it leaking from?
Old Jan 31, 2005 | 02:27 PM
GSR_Jamee's Avatar
Default Re: (skunked)
um..its leakin i THINK from a hose somewhere on the bottom..but im not really sure.
EDIT: its leakin from the top passenger side....NOT THE BOTTOM, NOT FROM A HOSE
Modified by GSR_Jamee at 8:45 AM 2/3/2005
Old Jan 31, 2005 | 02:32 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR_Jamee &raquo;</TD></TR><TR><TD CLASS="quote">um..its leakin i THINK from a hose somewhere on the bottom..but im not really sure.</TD></TR></TABLE>
You really need to look at your car. Find the leak so we can help you from there.
Edit: GSR_Jamee is a female
Modified by skunked at 4:18 PM 1/31/2005
Old Jan 31, 2005 | 03:08 PM
HONDA_TYPE_R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
You really need to look at your car man. Find the leak so we can help you from there.</TD></TR></TABLE>
Guess he didn't peep your signature...I would advise that you trace down the source of the leak. Without knowing where it is actually leaking from, it will be somewhat tougher to find the problem. If it's coming from a hose, try to pinpoint which one (not too many) it is. From the sounds of it though...you have a bad head gasket. Have someone stand behind your car and see if the exhaust has a sweet smell or is very white. If the engine is knocking, it may be from coolant spilling into the cylinder and the engine trying to compress it...water doesn't compress, so your rings will give up first. If your knocking, you may want to do a tear down after you figure out what the problem is...knocking will destroy your rings, pistons and sleeves. How severe is the knock? Occasional or often? Also is it in multiple cylinders? Got to stop banging VTEC so much!!!
Old Jan 31, 2005 | 03:17 PM
skunked's Avatar
Default Re: (HONDA_TYPE_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R &raquo;</TD></TR><TR><TD CLASS="quote">
Guess he didn't peep your signature.</TD></TR></TABLE>
Oh $hit....LOL
I didn't even notice that
My bet is the head gasket with a possible rod knock.
Old Jan 31, 2005 | 05:22 PM
GSR_Jamee's Avatar
k...i tracked the leak down, but still not 100%. more like...80%. if her lookin at the car (as if you were standing in front of my avatar) thhe leak is comin from the left side...(passenger side). its comin from the radiator...towards the bottom left. the knocking, i didnt notice it until last night. i heard it this morning but it was really short and wasnt as loud as last night. (but then again, i didnt drive my car so it didnt get as warm vs driving to the airport last night)
EDIT: NVM the question. the leak is comin from the TOP of the radiator. nothin to do with that bump...no more knocking, no smoke (never was)
Modified by GSR_Jamee at 8:44 AM 2/3/2005
Modified by GSR_Jamee at 8:46 AM 2/3/2005
Old Jan 31, 2005 | 08:22 PM
Get a new radiator...may as well splurge and get a Fluidyne, Koyo, or even C&R. They are AWESOME. Keeps the car cool as ****. Hope everything works out for you.
Old Jan 31, 2005 | 09:36 PM
confucius's Avatar
if its like, kinda shaking, then theres a leak somewhere in the hose. i had the problem on the upper line.
had a small hole and the car was shaking preety bad.
replaced the hose, and no more shaking.
dont know why, but yeah, it worked.
Old Feb 1, 2005 | 07:21 AM
GSR_Jamee's Avatar
Default Re: (confucius)
naw, its not shaking. but it does idle funny. i left some pans under my car this morning to see how much would leak out...and not a lot did. so now im confused...if its cracked..shouldnt it leak just as much as it did before?
Old Feb 1, 2005 | 07:28 AM
skunked's Avatar
Is the car smoking at all? (out the tailpipe)
Old Feb 1, 2005 | 10:14 AM
GSR_Jamee's Avatar
nope..no smoke comin out.
Old Feb 1, 2005 | 10:45 AM
skunked's Avatar
Have the leak delt with then go from there. Have you noticed the temp gauge over the half way point at all?
Old Feb 1, 2005 | 02:08 PM
GSR_Jamee's Avatar
yesterday i didnt notice that if my car was over heating or not because i didnt drive it and i never let it warm up. so i took it to autozone, and yes...it did pass the 1/2 way mark, it went all the way up to 'H'. so on my way to autozone, i had to park on the side and let it cool off a little. i forgot what it was called, but an EX fix for the radiator, it looks like liquid gun powder and its suppossed to seal any cracks from the inside. so i let my car cool down, put it in, and topped off with coolant. no more leaks...no more over heating. but thats just a quick fix, im not relying on it for too long. i need a new radiator.
Old Feb 1, 2005 | 02:56 PM
NOOOOOOO!!!!!!!!!!! That EZ fix **** is the devil. I tried it on an emergency radiator rupturing (why I know have a Fluidyne), and it clogged up some of the coolant passages (small ones) on my old motor a little. I have heard of this stuff doing this to other vehicles too. When you replace your radiator, you should FLUSH THE **** OUT OF YOUR SYSTEM. It can be a hinderance and nuisance later. Good luck, and I hope all turns out well for you.
Old Feb 1, 2005 | 03:00 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R &raquo;</TD></TR><TR><TD CLASS="quote">NOOOOOOO!!!!!!!!!!! That EZ fix **** is the devil. I tried it on an emergency radiator rupturing (why I know have a Fluidyne), and it clogged up some of the coolant passages (small ones) on my old motor a little. I have heard of this stuff doing this to other vehicles too. When you replace your radiator, you should FLUSH THE **** OUT OF YOUR SYSTEM. It can be a hinderance and nuisance later. Good luck, and I hope all turns out well for you.</TD></TR></TABLE>
Yeah, that **** sucks. Like he said, replace your radiator, flush your motor and see what happens. If that knock comes back or if it overheats again you may have a headgasket/head warpage issue.
Old Feb 2, 2005 | 02:04 PM
GSR_Jamee's Avatar
thanks for the suggestion. ill be sure to flush it when i get a new radiator (hopefully soon...low on $$).
Old Feb 3, 2005 | 07:48 PM
Del Sol SiR's Avatar
also replace the radiator cap and bleed the coolant.
mnaffay205
Nov 7, 2014 06:42 AM
alvinahmed
Sep 16, 2012 09:32 AM
donald810714
12
Feb 6, 2010 04:12 PM
wdissident
26
Mar 20, 2009 01:23 PM
Mattyg2
Mar 6, 2004 08:24 AM
