I hate to whine, but my car did it first!
Old Jan 31, 2005 | 07:47 AM
FakeJDMEF8's Avatar
Default I hate to whine, but my car did it first!
so last week i was driving and started to notice a slight whine coming from the from paseenger wheel area. its slight and isnt grinding, its almost a brake whine? cant tell. or my ES bushings? its starting to annoy me, just because it didnt before. the CV joints are new and the brake pads were replaced and rotors were turned a month or two ago. i cant seem to pinpoint it at all, and no searches came up with similar situations, unless its the dist, or alternator. any suggestions, or any ways to check? 90 CRX Si w/B16a. doesnt do it past 4-5k
im stumped.
Old Jan 31, 2005 | 07:51 AM
fastassdx's Avatar
From: Come back next year and Ill put some, eggnog in your face, US
Default Re: I hate to whine, but my car did it first! (FakeJDMEF8)
well, my car has about ten different whines, the loudest is from the speedometer cable. hope this helps
Old Jan 31, 2005 | 07:54 AM
PHOBIA's Avatar
does it clunk? if it does its a wheel bearing.the ****** who put my new motor fucked up all kinds of **** including not tightening my passenger axle enough,i in turn get a ficking broke *** wheel bearing and a fucked rotor.good times huh?
Old Jan 31, 2005 | 08:04 AM
fireant's Avatar
Default Re: (PHOBIA)
clucth slipping? hard to say without hearing it.
Old Jan 31, 2005 | 08:12 AM
vegaskurt's Avatar
Default Re: (fireant)
does the whine go away when you brake? I got the same thing. I think its my cheap pads.
btw, speedo cable whine is cake to fix. get a can of white lithium grease, pull the cable, spray, replace and enjoy. takes 10 min todo.
Old Jan 31, 2005 | 05:19 PM
FBPSidan's Avatar
Default Re: (vegaskurt)
i have the same 2 whines.... well i got more of a chirp coming from what the guy that sold me the car said is the speedo cable... i had no idea it was that easy to fix.... good lookin out
Old Jan 31, 2005 | 05:23 PM
bucketheadCRX's Avatar
Default Re: (VegasRex90)
i have the "alternator belt is slightly loose whine/whistle" when i turn my lights on(or right at start-up)..our cars could start a boy band
Old Feb 1, 2005 | 02:17 PM
vegaskurt's Avatar
yeah just pop the cable off the tranny and do the same for behind the guage cluster. Its super easy to get to on these civics.
Then you can pull the metal inner wire of the speedo cable out of the sheath. Clean it off good, then spray it with some white lithium grease or anything similar. Spray a little into the sheath also. (To much and you'll cover your drivers seat in the stuff) Slide it back in and enjoy.
I had the whine for 2 years, it was worse in the winter. I was suprised how easy it was to fix.
Old Feb 1, 2005 | 02:22 PM
kulangot's Avatar
my dizzy whined, right before it went out....
Old Feb 1, 2005 | 03:09 PM
Chase's Avatar
Default Re: (buckethead36)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buckethead36 &raquo;</TD></TR><TR><TD CLASS="quote">i have the "alternator belt is slightly loose whine/whistle" when i turn my lights on(or right at start-up)..our cars could start a boy band </TD></TR></TABLE>
Thats so funny, its true too...all the rattles and whines. The chorus would be vtec...mmmmmBAHHHHHH
Old Feb 1, 2005 | 06:38 PM
Ef-er's Avatar
tranny bearing?
does it make the whine when clutch in?
Old Feb 3, 2005 | 11:44 AM
FakeJDMEF8's Avatar
all the time, even when braking, shifting, so on....its starting to be a bitch. any other suggestions???
Old Feb 3, 2005 | 11:50 AM
untitled's Avatar
Default Re: (FakeJDMEF8)
is there any variation in it realavent to engine RPMS? or when the clutch is depressed, or when you apply brake. It has to change sometime because if its whining its probably rotating, unless when your stopped its still doing it you can eliminate any suspension/brakes/wheels probs.
you see what i mean, process of elimination.
Old Feb 4, 2005 | 05:57 AM
FakeJDMEF8's Avatar
stops after slowing down to 15-20mph. sometimes it leaves for a while, then comes back. what should i look for, im going to pull the wheel off and look for something.
Fendyc718
Oct 10, 2012 07:22 AM
iDs748
Aug 21, 2009 01:54 PM
riceforlife
Nov 23, 2007 05:06 PM
youknowimwhite
Jan 4, 2007 08:11 PM
InLimbo87
Nov 2, 2005 01:55 PM
