Cam gear compatibility? Y8 gear on A6 cam
Old Jan 31, 2005 | 07:10 AM
90LSpimpin's Avatar
Default Cam gear compatibility? Y8 gear on A6 cam
Sup all, I picked up an AEM cam gear from a buddy for real cheap, wanting to use it on my A6. But from what I've read, it says that the 96+ cam gear will set the timing off by about 3-5 degrees. Being that its an adjustable cam gear i figure i could just......adjust it..... But does anyone know how much i would have to adjust it to get it stock? I have a D16a6 with Delta 272 camshaft and a Y8 headgasket (so i believe i was supposed to advance timing a little to compensate for that?). I've searched and cant get any definate answers. Thanks all
Old Jan 31, 2005 | 11:52 AM
90LSpimpin's Avatar
Default Re: Cam gear compatibility? Y8 gear on A6 cam (89SiPimpin)
Up, plz help, lookin to install soon.
Old Jan 31, 2005 | 12:00 PM
4drEF's Avatar
Keyboard Humorist
Take the A6 one off and match it to the Y8 one.
Make sure they have the same tooth count and are teh same diameter.
Then, make sure the woodruff keys are matched up and mark the Y8 gear accordingly.
Old Jan 31, 2005 | 12:06 PM
90LSpimpin's Avatar
Default Re: Cam gear compatibility? Y8 gear on A6 cam (4drEF)
The y8 one doesnt have the key, its built into the stock a6 gear. So i'm gettin ready to go pick one up from autozone.
Old Jan 31, 2005 | 12:31 PM
CRXDrew's Avatar
Y8 gear isn't the same, but I guess you can switch up the timing enough. As said above, make sure the teeth count is the same. 88-95 work on the A6.
AEM 3 bolt? Be careful and retighten after a couple miles driving on it I've heard they slip.
Old Jan 31, 2005 | 01:00 PM
90LSpimpin's Avatar
Default Re: (CRXDrew)
I heard your mom slips.
Old Jan 31, 2005 | 01:07 PM
mellon's Avatar
Default Re: (89SiPimpin)
I'm fairly certain the y8 cam gear has a 1/2 tooth difference compaired to the a6 cam gear.
Old Jan 31, 2005 | 01:26 PM
CRXDrew's Avatar
I'll slip into your mom.
Old Jan 31, 2005 | 01:34 PM
91civicEX's Avatar
Default Re: (mellon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mellon &raquo;</TD></TR><TR><TD CLASS="quote">I'm fairly certain the y8 cam gear has a 1/2 tooth difference compaired to the a6 cam gear. </TD></TR></TABLE>
im also fairly certain. for future reference 1/2 tooth= 5 degrees = or- but ull be alright setting it 5 degrees advanced or retarded.
austen95
Mar 12, 2018 06:55 PM
RNPoo7
Nov 21, 2006 06:20 AM
