silly question: how to run vortech supercharger and NO BOOST?
Old Jan 31, 2005 | 06:41 AM
Black R's Avatar
25 Year Member
Default silly question: how to run vortech supercharger and NO BOOST?
I just rebuilt this motor and don't trust the tune for boost.
It really needs hondata/ uberdata + bigger injectors.
I'd also like to break it in allmotor, so what would be the easiest way do this?
I'm thinking I'll just leave everything installed and simply disconnect the piping that goes to the throttle body.....
Or should I remove the blower belt?
Or both?
Or.....???
Old Jan 31, 2005 | 06:44 AM
Black R's Avatar
25 Year Member
Default Re: silly question: how to run vortech supercharger and NO BOOST? (Black R)
oops..... wrong forum.
I meant to post in the FI section.....
Can someone please move?
Old Jan 31, 2005 | 07:47 AM
Bbasso's Avatar
BAN the noobie
Old Jan 31, 2005 | 07:51 AM
Philly_NBP_R's Avatar
Default Re: silly question: how to run vortech supercharger and NO BOOST? (Bbasso)
take off the belt and disconnect the charge toob?
Old Jan 31, 2005 | 08:07 AM
DC2R714's Avatar
Default Re: silly question: how to run vortech supercharger and NO BOOST? (Philly_NBP_R)
Why do people still not understand that you are not in boost all the time? Even with a supercharger you are not going to be in boost all the time. It's load dependent people. Just don't press the gas pedal hard and you won't be in boost. Geez
PS. that wasnt pointed at you Nick just in general
Old Jan 31, 2005 | 08:25 AM
RTW DC2R's Avatar
how is a supercharger not in boost at all times? I can understand for a turbo, but a supercharger is running off the belt which is always turning no matter how much gas you are giving it or how much load is on the motor. not arguing, just questioning.
Old Jan 31, 2005 | 08:28 AM
Black R's Avatar
25 Year Member
Default Re: silly question: how to run vortech supercharger and NO BOOST? (DC2R714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote"> Why do people still not understand that you are not in boost all the time? Even with a supercharger you are not going to be in boost all the time. It's load dependent people. Just don't press the gas pedal hard and you won't be in boost. Geez
PS. that wasnt pointed at you Nick just in general </TD></TR></TABLE>
Yes, BUT I DON'T WANT TO BE IN BOOST EVER. Not while I'm breaking in the motor. I have to press the gas pedal to run through the rpm's and break in the motor properly.
Old Jan 31, 2005 | 08:31 AM
DC2R714's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, BUT I DON'T WANT TO BE IN BOOST EVER. Not while I'm breaking in the motor. I have to press the gas pedal to run through the rpm's and break in the motor properly. </TD></TR></TABLE>
Break it in with boost. **** I had 64 miles on my built motor and broke it in on the dyno with 9psi. My motor is still perfect. Break it in like you will drive it.
Old Jan 31, 2005 | 08:37 AM
sneakychaos's Avatar
Default Re: (RTW Ryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan &raquo;</TD></TR><TR><TD CLASS="quote">how is a supercharger not in boost at all times? I can understand for a turbo, but a supercharger is running off the belt which is always turning no matter how much gas you are giving it or how much load is on the motor. not arguing, just questioning. </TD></TR></TABLE>
its not boosting if theres no belt spinning it.
even if you leave the plumbing in place, this particular motor (note: IMHO) will not come close to enough airflow to spin the blower.
then again, I've been up for the past 52 hours straight and I could be dead wrong.
Old Jan 31, 2005 | 08:45 AM
Splat's Avatar
Collector-o-Guns and Drinker
Break it in with boost. **** I had 64 miles on my built motor and broke it in on the dyno with 9psi. My motor is still perfect. Break it in like you will drive it. </TD></TR></TABLE>
R0cker doesn't trust the tune. Simple reason for not breaking it in with boost.
Old Jan 31, 2005 | 09:13 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">I just rebuilt this motor and don't trust the tune for boost.
*sigh*
Do people just not read anymore.....?
It seems that they just see the thread title, click on it, then click reply.....
Old Jan 31, 2005 | 09:17 AM
break it in with some NAWZZZ instead yO
Nate - we all understand how wastegates work, but it's virtually impossible to drive a turbocharged car on the street without producing at least some boost (unless you have a humongous T4 or some ****). A supercharged car will definitely make boost no matter how you drive it.
Rocker, I would just take the belt off, and disconnect the charge pipe. Hell, I would take the whole damn thing off and slap a pep boyz racing filter on there till it's broken in.
A better approach might be to get the thing tuned before you break it in, so you don't have to worry.
Old Jan 31, 2005 | 10:27 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">Rocker, I would just take the belt off, and disconnect the charge pipe. Hell, I would take the whole damn thing off and slap a pep boyz racing filter on there till it's broken in. </TD></TR></TABLE>
He's worried about the tune.
But yeah, Ken-- Spinning a supercharger with no load should NOT cause any issues! So leave the belt on if it's easier. You should reroute the intake pipe, the flow through a not-spinning supercharger would probably suck bad. Stick a generic filter right on the TB if you want, if you don't care about where the valve cover breather is going.
Tune it.
-Chris
Old Jan 31, 2005 | 12:23 PM
DC2R714's Avatar
Default Re: silly question: how to run vortech supercharger and NO BOOST? (Chris F)
Ok maybe you guys arent getting what I am writing. When I said break it in with boost I meant while tuning it. Ask Jeff Evans (boosted-hybrid) how he breaks in the motors he builds. He puts them directly on the dyno to break them in.
Secondly a Supercharger is connected with a belt and will spin with the motor but that does not mean it will create boost. The vortech kit uses the compressor of a turbo connected to a shaft which is belt driven. Superchargers pull with load and RPMs. Taking out the load it will still spin and wine but shouldnt create boost.
or I might be smokin crack. Caaaaaaaan yooooou diiiiiiiiiiig it!
Also if you were always in boost with a supercharger it would be a maad tyte idle y0
Old Feb 5, 2005 | 07:55 AM
dategb16vortech's Avatar
vortech chargers have a minature like transmission that steps up the speed of the compressor depending on load. If you don't give it hell you will not be in boost. When I was breaking mine in there would be plenty of times where I was at partial throttle and no boost would show on my boost gauge so to say that superchargers are always in boost, is incorrect. to say they are always ready for boost and there is very little to no lag at all, is correct
Old Feb 5, 2005 | 08:52 AM
Yellow Dragon's Avatar
Remove the belt. No worries.
Old Feb 5, 2005 | 09:00 AM
1GreyTeg's Avatar
Get that red flippy switch thing that Mad Max had.
Flip it on when you need to catch a bike.
Flip it off before you run outa petrol.
Old Feb 5, 2005 | 10:16 AM
B2FiNiTY's Avatar
Default Re: silly question: how to run vortech supercharger and NO BOOST? (1GreyTeg)
Get it tuned immediately so your motor is running the correct af during its break in.
Old Feb 6, 2005 | 03:13 PM
Default Re: silly question: how to run vortech supercharger and NO BOOST? (B2FiNiTY)
what he said get it tuned right away don't wait till motor blows. My buddy got his mototr built at Kenny Tran's shop and it made almost 900 hp in a civic SI. Kenny told him they actually break most of their cars in on the dyno
Old Feb 15, 2005 | 08:21 PM
Black R's Avatar
25 Year Member
Default Re: silly question: how to run vortech supercharger and NO BOOST? (Yellow Dragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yellow Dragon &raquo;</TD></TR><TR><TD CLASS="quote">Remove the belt. No worries. </TD></TR></TABLE>
vortech uses a serpentine belt for the blower and ac pulley's at the same time...
no belt on blower = no air blowing out of the ac...
I just disconnected the charge pipe.
Old Feb 15, 2005 | 10:07 PM
justahobbie's Avatar
If I had the money I would honestly tune the motor so you can break it in with boost. I have always been a firm believer in breaking in ANY engine how it will be run in day to day operations. Otherwise, disconnecting the pipe like you did should work.
turbotime
Oct 6, 2005 05:54 PM
B16Civic93
Jul 13, 2005 02:12 PM
evilk
May 25, 2005 06:39 PM
The Poopsmith
Dec 14, 2002 01:35 PM
LOwrestling2001
Sep 5, 2002 03:25 AM
