Leaky fuel lines under car.
Old Jan 31, 2005 | 03:47 AM
JimBlake's Avatar
Default Leaky fuel lines under car.
My '95 GSR 4-door just started leaking fuel.
Looks like the fuel lines running under the floorpan got rusty. I started taking those lines off, but the brackets holding them are strange.
Has anyone done this? What's the trick to get the brackets apart so I can leave the brake lines in place? Do you have to take the whole thing down before you can get each line apart?? If so, maybe I'll have to replace the 2 brake lines, too.
Old Feb 4, 2005 | 03:57 AM
JimBlake's Avatar
Default Re: Leaky fuel lines under car. (JimBlake)
hmmmm thanks for the help...
So, just in case someone finds this thread by searching, replacing those lines is a nasty job. Where they feed around the corner at the bottom of the firewall, you can't get them thru without lowering that rear subframe of the front suspension. Now I gotta get it towed somewhere... Or maybe sell it...
lurchy
Dec 22, 2014 07:58 PM
anthonycox28
Dec 11, 2013 06:15 PM
renegadez7o7
Oct 26, 2007 06:45 PM
Sloshy
11
Nov 2, 2006 06:09 AM
