input shaft bearing cause rpms to fall slowly?
Old Jan 30, 2005 | 09:58 PM
user 98292739's Avatar
Default input shaft bearing cause rpms to fall slowly?
So i know my input shaft bearing needs changed out, but the problem isnt me popping out of gear. After teh car is warmed up my rpms fall super slow after i release teh clutch. Keep in mind that this only happens when the car is warmed up. When it is cold rpms drop fast like normal. I dont know if i should mention this too but one day i got in the car and the clutch caught as soon as i lift my foot up. Before i had it so it caught near the middle. So im not sure if the cable is kinked. i readjusted the clutch cable but i cant get it to catch in the middle anymore. It almost seems like the clutch isnt all the way released. I looked around and checked the throttle body and everytrhign else still no go. It just baffles me that this only happens when it is warmed up. The rpms just sit there for like a 1 sec then it slowly drops down after i step on the pedal. Another thing is when i just let the car cruise meaning not touching the gas but letting it cruise in gear it back fires....this is getting really annoying because one the backfires are pretty loud sometimes...and when i switch gears the car jolts like i am a newbie at clutching. any help would be great! thx!
Old Jan 30, 2005 | 10:05 PM
4DRmafia's Avatar
dizzy plms? i dont think a input shaft bearing have anything to do with this ....correct me if i am wrong
Old Jan 30, 2005 | 10:50 PM
you think it might be a faulty dizzy? but how would that explain the over night clutch cable tightening? and that wouldnt cause rpms to drop slowly would it?
Old Jan 31, 2005 | 08:15 PM
still dropping slowly!
Old Jan 31, 2005 | 08:25 PM
sporkcrx's Avatar
Default Re: input shaft bearing cause rpms to fall slowly? (LoCoReX)
It falls slow when you push in the clutch pedal? If so, it has nothing to do with the tranny.
Old Feb 1, 2005 | 02:49 PM
as soon as i push in the clutch it hoovers there for like .75 secs then VERY SLOWLY falls. so wheni engage my next gear the car jolts.
Old Feb 1, 2005 | 04:55 PM
vegaskurt's Avatar
Default Re: (LoCoReX)
After the car is warmed up and all, can you push the clutch in and roll the car with it in gear (motor off)?
Old Feb 2, 2005 | 01:42 PM
i am not sure....so your saying when its warmed up hold clutch in and go have somone push the car while car is off and hot?
d16efsedan
Transmission & Drivetrain
Apr 9, 2013 12:02 PM
nnamssorxela
30
Jun 29, 2011 11:09 PM
CLE
Sep 16, 2006 03:59 PM
R_type
May 31, 2005 05:40 AM
senpai
Apr 30, 2002 01:15 PM
