15/16" vs 1" Master Cyclinder
I have a 94 Civic DX with GSR suspension. I know that if I go with a 15/16" from a 91 Civic EX or 94 Integra RS, there would be no modificaitons, just simple bolt on..But I am curious if I go with the 1". How much of a difference would I feel with my Power Slot rotors and what kind of mods would I need to do for a 1".
integra 1" you will need the integra booster. and depending on what year m/c you will have bend the front brake line, or you will have a 12mm side brake line you will have to reflare. but you will have to look at the m/c to see what you will have to change... i got a m/c from a 99 integra ls with abs and i only had to bend the front brake line.
i have gone from 13/16 to 15/16 and to 1" all with gsr brakes all around. 1" is night and day compared to the other two.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">integra 1" you will need the integra booster. and depending on what year m/c you will have bend the front brake line, or you will have a 12mm side brake line you will have to reflare. but you will have to look at the m/c to see what you will have to change... i got a m/c from a 99 integra ls with abs and i only had to bend the front brake line.
well put!
well put!
oh and dont let anyone tell you the itr m/c and booster is better. all 98+ integra (all trims) with abs systems are all the same 1". some fools like to advertise " itr m/c brake booster" like its different then the lower model 98+ integras.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ2_B16 »</TD></TR><TR><TD CLASS="quote">I have a 94 Civic DX with GSR suspension. I know that if I go with a 15/16" from a 91 Civic EX or 94 Integra RS, there would be no modificaitons, just simple bolt on..But I am curious if I go with the 1". How much of a difference would I feel with my Power Slot rotors and what kind of mods would I need to do for a 1".</TD></TR></TABLE>
with the 15/16 off a 91 EX, it will bolt in. with the RS 15/16, you need the integ booster too.
i have gone from 13/16 to 15/16 and to 1" all with gsr brakes all around. 1" is night and day compared to the other two.</TD></TR></TABLE>
did u go from 15/16 with civic booster to 1" with teg booster? was the difference THAT much? i have a 15/16 with civic booster and brake is pretty good. i can really lock 'em up if i get on 'em really hard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
did u go from 15/16 with civic booster to 1" with teg booster? was the difference THAT much? i have a 15/16 with civic booster and brake is pretty good. i can really lock 'em up if i get on 'em really hard.</TD></TR></TABLE>
yes i had civic m/c and booster with the 13/16 and 15/16 m/c's with gsr full brake swap. i could stop pretty good. but i went to 1"mc and integra booster when i had a good deal. and i must say if i know what the brakes were on the 1" set up i never would have wasted my time and money on the 15/16. the 1" gives you better modulation as you brake. i know some will say no it doesnt. im not here to argue with them. all i know i would never go back to 15/16 setup... and this better feel is most likely due to the bigger booster and being able to push through more pressure to the calipers...
Is the 91 Civic EX/94 Integra RS MC 15/16"? Or isn't the 15/16" from like GS-R's? Because I know the GS-R has a larger piston than the LS's.
Anyway, where is a good place to find the 1" MC/booster combo? I've tried the junkyards already and no luck.
Hey everyone, thanks for the help. Although, what are the cons in bending the front brake lines.. I have brand new Goodridge lines that have never been installed yet..what do I have to do to those..Thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ2_B16 »</TD></TR><TR><TD CLASS="quote">Hey everyone, thanks for the help. Although, what are the cons in bending the front brake lines.. I have brand new Goodridge lines that have never been installed yet..what do I have to do to those..Thanks again</TD></TR></TABLE>
When we say bend the brake lines we mean the hard lines in the engine bay. The position that the lines exit the MC on the ITR MC is different from the way they enter your MC. You can however get some custom braided brake lines made so that you don't have to bend those lines, you can just replace them.
well dude I did my rear disc conv on my ek hb and I used the 00 civic si prop valve and the MC and now my breaks rocks nice!!
I know that if I put the ITR MC which is 1' would be alot better , but for right now they are nice I am planning to do the ITR MC later on to see if it really makes some difference!!
Check http://www.goodridge.net , they have a list of places that make custom lines in every state.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">I think you would be at a disadvantage. The 7/8 is .875" and the 15/16 is .97" something. So the 15/16 would be better than the 7/8.</TD></TR></TABLE>if this is true, why does the EK hatch backs come with 15/16 and the coupes including the Si come with 7/8?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by issues_ek »</TD></TR><TR><TD CLASS="quote">well dude I did my rear disc conv on my ek hb and I used the 00 civic si prop valve and the MC and now my breaks rocks nice!!
I know that if I put the ITR MC which is 1' would be alot better , but for right now they are nice I am planning to do the ITR MC later on to see if it really makes some difference!!</TD></TR></TABLE>
Coming from the dealership, the EK's prop valve have the same part # of the 99/00 Si's prop valve. On my buddy's EK, we didn't even change the booster/MC for his 5-lug conversion. Although, I would have recommended changin' at least the MC and the booster, had he gotten the 1" MC.
taney
Feb 9, 2009 12:31 PM
taney
Jan 16, 2006 02:34 AM
EJ2_B16
18
Jan 25, 2005 09:46 PM
navin
Jan 14, 2003 06:36 PM
