battery relocating
Old Jan 30, 2005 | 07:40 PM
hondime9396's Avatar
Default battery relocating
i'm moving my battery to the trunk, with the amount of wire needed is it a good idea to install an inline fuse if so what amp should it be?
Old Jan 30, 2005 | 09:06 PM
Okley_01's Avatar
Default Re: battery relocating (hondime9396)
Yes, you need to run an inline fuse no more than a couple feet away from the battery. If you didnt, you would be running a serious risk of catching your car on fire if something shorted out. For my app, I just used my stereo fuse (40amp)
Old Jan 30, 2005 | 09:28 PM
ricepicker's Avatar
Not sure on the wire I imagine it will be quite a bit, since you will be running it to the back and back to the front. Monster Cable makes some circuit breakers, they are really handy and you don't have to ever buy more fuses. But if you ever plan on taking it to the racetrack, you will need to have a vented battery box if it is not dry or gell cell . Also you are required to have a kill switch mounted on the exterior of your car.
Old Jan 31, 2005 | 09:47 PM
Default Re: battery relocating (ricepicker)
wow, i didn't know there was so much involved in a "simple" relocation does it really even make it worth doing all of that?
Old Jan 31, 2005 | 11:03 PM
ricepicker's Avatar
Just curious.... Why are you moving it?
Old Feb 1, 2005 | 04:13 AM
FSTASNTZ's Avatar
My 1999 required about 16 ft of wire to do the relocation properly.
Jason
Old Feb 1, 2005 | 10:08 AM
well i removed a ton of **** to clean up my engine bay like ac/ powersteering, and all my emissions clutter evap canister stuff like that and i'm also moving the fuse box inside as well as the battery to the trunk
Old Feb 1, 2005 | 10:20 AM
jakeiscool's Avatar
Banned
batteries are fairly heavy and when you have an accord you need all the help with weight distribution you can get.
Old Feb 6, 2005 | 09:49 PM
Default Re: battery relocating (JakeIsCool)
word
Old Feb 7, 2005 | 08:18 AM
twkdCD595's Avatar
I used a good quality welding cable back to an optima in the trunk.
While your making up cables you can use the extra you have to make some extra grounding tails.
Old Feb 9, 2005 | 07:01 PM
bez's Avatar
bez
can u help me my 80 amp battery fuse blow what is the cause and how do i hook it up 91 accord lx
84Riceeater
Oct 27, 2017 11:43 AM
91-lsvtecsi
Mar 15, 2012 04:14 PM
Emmanuel2112
Jun 24, 2008 06:10 AM
SlowDown
Audio / Security / Video
14
May 14, 2007 12:11 PM
4doorH22
Nov 27, 2001 09:32 AM
