e-brake light wont go off! why?
Old Jan 30, 2005 | 07:13 PM
tallblondkid's Avatar
Default e-brake light wont go off! why?
for some reason my e-brake light wont go off...
about a week ago the e-brake light would come on when i make a hard left or accelerate hard and then go off if i jerked right or randomly.... but now it doesnt seem to go off at all... anyone have any input?
Old Jan 30, 2005 | 07:15 PM
numbnuts22715's Avatar
check your brake fluid? if its low it can cause it to not turn off.
Old Jan 30, 2005 | 07:33 PM
Default Re: (numbnuts22715)
thanks alot, ill check it in the morning
anyone else?
Old Jan 30, 2005 | 07:36 PM
Ricey McRicerton's Avatar
Default Re: (tallblondkid)
99% sure it's your brake fluid level.
EDIT: Hell, I'll elaborate why I think it's this. You said it only comes on under acceleration and cornering. There is a float in the resovior that determines when the light comes on. If you have a resovoir that is less than full, when you do those motions, the float sinks to the level that would allow the light to come on.
Old Jan 30, 2005 | 07:43 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">99% sure it's your brake fluid level.</TD></TR></TABLE>
i'll have to second that and say 99.99%
Old Jan 31, 2005 | 07:34 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (rodney)
Hahaha. Directly after a rear disc swap, my e-brake light was on. I took the whole consol/e-brake apart & fucked around with that for about an hour, before I realized I just didn't fill the resivoire up enough after bleeding.
The brake light is supposed to be your first sign of worn brake pads. If it's low, you sould check your pads, because their probably wearing thin.
Old Jan 31, 2005 | 08:21 AM
Jago's Avatar
Default Re: (94eg!)
if its not fluid level the cap sensor can go bad causing the light to stay on
Old Jan 31, 2005 | 08:31 AM
Default Re: (Jago)
well, you guys were right, i was low on fluid, thanks
Old Jan 31, 2005 | 08:32 AM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallblondkid &raquo;</TD></TR><TR><TD CLASS="quote">well, you guys were right, i was low on fluid, thanks</TD></TR></TABLE>
Just make sure you figure out why it was low on fluid (it doesn't happen for no reason).
Old Jan 31, 2005 | 08:34 AM
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">
Just make sure you figure out why it was low on fluid (it doesn't happen for no reason).</TD></TR></TABLE>
Very good idea. Check around the brake lines (where they attach to the hard lines and the brake calipers. Also check your pads to see if they're worn.
Old Jan 31, 2005 | 12:28 PM
pads are not worn, brand new, maybe i didnt tighten a line hard enough, although its been 5 months, slooooow leak
lowRIDAH
11
Jul 22, 2005 01:37 AM
JOJO0420
Feb 23, 2005 08:41 AM
BigZ88
Feb 21, 2005 09:17 PM
SwampThing
Jan 11, 2005 03:30 PM
Charles B.
May 10, 2002 11:43 AM
