Mini-Me Compression
Ok I used a compression calculator to find out what the compression of my engine (d16y7/y8 mini me) was. It said it was somewhere around 13.9:1 to 14.5:1. (Im not sure what headgasket is on there, y8 or y8 two layer, the y8 being 13.9:1). Is that estimate correct?
The Y7 pistons actually have a greater dish than the Y8 pistons, so a Y7/Y8 mini me has a lower compression ratio than a stock Y8 (stock Y8 is 9.6:1)
I would guess in the 9.2-9.3 range (same as D16Z6)
y7/y8 compression is 9.9:1
i used this:
http://www.knology.net/~jediklc/D.htm
and everything i've punched in it so far has been 100% correct so i trust its mini-me calculation
i used this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkailburn »</TD></TR><TR><TD CLASS="quote">y7/y8 compression is 9.9:1
i used this:
and everything i've punched in it so far has been 100% correct so i trust its mini-me calculation</TD></TR></TABLE>
I don't think thats correct. Notice how there is no value for the Y7 piston...
A standard Y8 is 9.8:1, so a Y7/Y8 mini me (basically a Y8 with Y7 pistons) would have lower compression because the Y7 pistons have a larger dish.
i used this:
Just to ball-park it, what's the compression ratio for just the Y7 engine.
Since Y8 head has smaller combustion chambers, mini-me should have a higher compression
There fore, Mini-me should be between Y7 and Y8, right?
Y7 < minime < Y8
Y7 < minime < Y8
i thought a stock y7 was 9.4 and a y8 was 9.6
the piston-dome displacement value is over in the table.
it seemed to pump out all correct values when i was using it
JonGP4
29
Nov 21, 2003 10:35 PM
calculator, compression, compresssion, d16y7, d16z6, honda, lowering, mini, minime, pistons, ratio, stock, y7, y7y8, y8
