B20 swap in a 89 Si CRX having problems
I swapped a 99 B20Z into my 89 si crx used all LS Integra parts i.e.. Wiring harness, distributor, alternator, ECU etc. ... well the motor has a looping idle it starts and runs fine for about five mins no error codes or anything then the idle starts jumping 2500rpm back to 1500rpm. I have checked for all vacuum leaks and and cant find anything wrong there. any suggestions
Is it thowring any codes, if so check em out. Also, make sure that your timming is on, (cam). ect. Check to make sure that you dont have any bubbles in your coolant, Ive herd of some weird stuff happening to engines when there is air in the coolant system. Double check your engine ground and thermostat ground... What OBD are you running?
Blaze
Blaze
From: Come back next year and Ill put some, eggnog in your face, US
hey I have a b20 ( crvtec) in my 88 HB DX and I am running the pr3. mine did not want to run at first at all as well. what fuel injectors are you running. I am using 96 accord injectors with a ristor box. let me know if you get it going and what was wrong please, thanks
yea i checked the fitv because i had that prob before when i swaped a b18 in my friends crx oh and im runnin 92 intergra LS injectors
Yes you will need obd-0 injectors. But I have of running obd1 with the resistor box in.
IACV could be clogged or partially anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive »</TD></TR><TR><TD CLASS="quote">Yes you will need obd-0 injectors. But I have of running obd1 with the resistor box in.
No, he won't. He can use 92 injectors, as long as the resistor box is out... I'm running OBD-O b16 injectors with an OBD-I ECU.
oops I said it wrong..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive »</TD></TR><TR><TD CLASS="quote">I have HEARD of running obd1 with the resistor box OUT
That is exactly what I meant to say sorry about that. I must have been tired last night.
its a fast idle problem, either timing is off or wiring is incorrect. set timing again (make sure its set at the 3 dots and not the one dot on crank pulley) and set idle at 900 when car is warm, it should go away after a few min, if not, then check your idel air controller
you dont have cams or cam gears do you?, and is the cel on? it has to be on if its fast idleing. sometimes i noticed if everything is right, it just takes time, then it goes away. this is if you make sure the timing is right
sometimes you can't see vaccum leaks. a trick that was shown to me by an old car guy is to buy a can of starting fluid and spray it on different parts of the engine where vaccum leaks could be. if theres no leak in that area, nothing will happen, but if there is a leak, it will pull the starting fluid in and the engine will rev up. this helps determine if and where a leak is.
Ok well after several long hours spent reading both an integra manual and a CR-V manual it turned out to be the FITV valve after all. Turns out that the automatic CR-Vs didn't use the FITV which my block came from an auto CR-V and it did not have the port in the water neck for the second hose coming off the FITV to train back into the block so it was just staying wide open after it warmed up and that caused the surging idle. So i T'ed off the IAC return hose that runs behind the motor and presto the problem is solved. God #@% Fitv valves thanks guys for your suggestions. Now if my header would hurry up and come in so i can finish the exhaust system id be ok
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89CRXD16y7 »</TD></TR><TR><TD CLASS="quote">Ok well after several long hours spent reading both an integra manual and a CR-V manual it turned out to be the FITV valve after all. Turns out that the automatic CR-Vs didn't use the FITV which my block came from an auto CR-V and it did not have the port in the water neck for the second hose coming off the FITV to train back into the block so it was just staying wide open after it warmed up and that caused the surging idle. So i T'ed off the IAC return hose that runs behind the motor and presto the problem is solved. God #@% Fitv valves thanks guys for your suggestions. Now if my header would hurry up and come in so i can finish the exhaust system id be ok </TD></TR></TABLE>
I hate to say it but i told you so.
brandon43
Oct 8, 2009 08:36 AM
