What sprocket(s) should i go with???
Old Jan 30, 2005 | 03:27 PM
85's Avatar
85
Default What sprocket(s) should i go with???
I have a 99' 900RR with stock gearing. Im getting ready to convert from a 525 to a 520 because the tensile strength difference is like 2% weaker. i want to lower my gearing but i don't know how low is too low. my stock is 16/43 i was thinking 2 down 2 up which would lower it by 28% so when im on the freeway at like 75mph it will make my RPMS about 1200 higher. is that going to be overly bad? does anyone have a 900RR with lowered gearing? what can you tell me?
Old Jan 30, 2005 | 03:44 PM
.Ash's Avatar
2 down worrys me; may run into some problems with the front sprocket being too small. 1 down 1 up is always a decent step, maybe even 1 down 2 up.
Old Jan 30, 2005 | 03:45 PM
LVB18Civic's Avatar
Default Re: What sprocket(s) should i go with??? (hks85)
That's alot of gearing unless you plan on doing 12's and circle wheelies. I have 1 down and 2 up and I love it. Perfect gearing for me.
Old Jan 30, 2005 | 06:05 PM
Etylorcen's Avatar
Default Re: What sprocket(s) should i go with??? (LVB18Civic)
2 down is too much for that front sprocket. What do you plan on doing? Are you just stunting? Like usdm said, 1 down 2 up or 1 down 1 up is pretty much the standard to increase midrange without too much sacrifiece of top end and freeway rpms.
Old Jan 30, 2005 | 09:08 PM
85's Avatar
85
Default Re: What sprocket(s) should i go with??? (Etylorcen)
Can i run a 108? that the size recomended for my bike "stock gearing" 1 down 2 up
yeah i do stunt a little but not enough to smash in my fuel tank
Old Jan 31, 2005 | 08:01 PM
RollaAce's Avatar
I would do what they say. Is your swingarm stock length, do u wanna stunt? My swing is stretched 4" so I can get a little radical here. I haven't put my 2 up sprocket on yet I'm waiting for the first full week of warm weather and for the tracks to open to see what kinda times I get with each mod (bigger pipe, rejet, K& N filter, then 1 down on front) That should do it for me. Good luck.
Old Feb 2, 2005 | 05:41 PM
85's Avatar
85
Default Re: What sprocket(s) should i go with??? (900RRBikerBoy)
ive been thinking of doing a stretch on my bike. throw that K&N away Factory Pro makes a much better filter kit (WAY MORE POWER!!!) for about $190. how much did that stretch cost? how did it affect you handling? can you still wheelie with it a little? any other draw backs?
Old Feb 2, 2005 | 06:05 PM
ProjectF4's Avatar
i need to get some new teeth too... and well, im thinking about going 1 down in the front, thats all... anymore and idk.. i don't want to
Old Feb 2, 2005 | 08:41 PM
immortal's Avatar
Banned
going down on the front sprocket puts a lot more stress on your chain versus going up in the rear...
i think you should go 1 down 2up at the most.
Old Feb 3, 2005 | 06:03 AM
ProjectF4's Avatar
Default Re: What sprocket(s) should i go with??? (immortal)
really? never knew that, then 2 up in the rear it is, and if i were to do that this spring, should i def. change the front sprocket too?
Old Feb 3, 2005 | 11:55 AM
Boughetto's Avatar
New User
Default Re: What sprocket(s) should i go with??? (ProjectF4)
I have -1/+2 on my 600. I just liked the extra down low power. I've run Vortex for 2 years now, get something else. Sprocket Specialist is good. Vortex rears are aluminum, meaning they only last a year.
jdm_tim
Nov 15, 2005 03:37 PM
4DRmafia
13
Aug 5, 2004 04:44 PM
lowlight
31
Dec 5, 2003 08:21 PM
CXHatchback
24
Jan 14, 2003 07:07 PM
