Wires Cut and Harness Disconnected Under the Hood
I just picked up a 98 Civic DX about 2 weeks ago. I keep finding new features ie. wires cut, holes drilled, and screws and bolts missing. I havn't found anything too major until now. I found this harness disconnected and some wires cut. I thought maybe this is for the air bag but my SRS light has never indicated a problem. I hooked the harness back up and started her up. No change in performance and no new indicator lights on my cluster. I have checked in my Haynes manual for information but didn't find anything. Any ideas on why it would be disconnected and the wires cut?
Harness is disconnected here. It's located just to the left of my drivers side headlight housing. The three wires that are cut are just below my pinky.
Here it is with the harness connected and the 3 wires are circled.
Maybe he had cruise control, p/s, a/c i duno if those have plugs but if its running and everything is okay its probably an option that he removed
Yeah that looks like ac to me. I'm guessing that your hand is where the ac compressor is supposed to go. So don't worry about those, they're for the ac. I'm 87.5% sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zekers »</TD></TR><TR><TD CLASS="quote">I just went out and took more pictures. So this is where the AC is supposed to go?
What a hack job.
What a hack job.
yeah, your compressor is on the block right under the power steering pump and tyhe condensor is next to the radiator. I noticed that you have the AC sticker on your core support, so the guy before you removed the AC. You should be fine, if you are worried about it tape them up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S(J)O(D)L(M) »</TD></TR><TR><TD CLASS="quote">
What a hack job.
y is that? if he had the a/c removed do you expext him to take out all the wires that run the a/c?i think not, i might have covered the wires and hid them but otherwise i dont see anything wrong
What a hack job.
</TD></TR></TABLE>y is that? if he had the a/c removed do you expext him to take out all the wires that run the a/c?i think not, i might have covered the wires and hid them but otherwise i dont see anything wrong
Zhu962
Apr 16, 2009 07:57 PM
JDM_EK_JOE
Oct 17, 2007 02:23 PM
