which valve springs and retainers with itr cams
Old Jan 30, 2005 | 10:12 AM
screaminvtec's Avatar
Default which valve springs and retainers with itr cams
i just put some 01 itr cams into my b16. im running a stock bottom end and an curious bout what everyone recomends. also have dc 4-1 header, testpipe, sunk2 catback, skunk2 cam gears which are set at +1 intake and -1 exhaust, and cai(which will be soon swaped out for password intake when it comes). let me know what kind of valve springs and retainers will be good to get. thanks
Old Jan 30, 2005 | 11:05 AM
Default Re: which valve springs and retainers with itr cams (screaminvtec)
bump
Old Jan 30, 2005 | 04:27 PM
paulITR's Avatar
Stock itr springs are better for itr cams... and can rev to 9000 rpm.
Old Jan 30, 2005 | 07:24 PM
Default Re: which valve springs and retainers with itr cams (paulITR)
thanks for the suggestion. i will be looking into that
Old Jan 30, 2005 | 07:56 PM
93gsrcoupe's Avatar
Do what paulITR said. Thats what I used with my gsr head.
Old Jan 30, 2005 | 08:46 PM
thevanitygroup's Avatar
Default Re: which valve springs and retainers with itr cams (93gsrcoupe)
I disagree. While stock springs are OK, for basically the same price you can pick up a set of omnipower springs which provide the same type of low seat pressure as the OEM springs but can handle larger cams and higher rpms without float. As for retainers the omnipower's will work wonders. This setup would allow you to hit 9500k+ rpms and not grind your cams with too stiff of a spring.
Old Jan 31, 2005 | 11:42 AM
Default Re: which valve springs and retainers with itr cams (thevanitygroup)
thanks for the info i think i might look into the omnipower springs
Old Jan 31, 2005 | 12:02 PM
projectegr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevanitygroup &raquo;</TD></TR><TR><TD CLASS="quote">I disagree. While stock springs are OK, for basically the same price you can pick up a set of omnipower springs which provide the same type of low seat pressure as the OEM springs but can handle larger cams and higher rpms without float. As for retainers the omnipower's will work wonders. This setup would allow you to hit 9500k+ rpms and not grind your cams with too stiff of a spring.</TD></TR></TABLE>
Best advice for you in the above quote. L
ook into supertech too. Or even if you wanted to skunk2, i believe these are a little more, but not much considering their ability to work well with bigger grinds. Good luck
Old Jan 31, 2005 | 12:48 PM
AllmtrSlut's Avatar
Default Re: which valve springs and retainers with itr cams (projectegr)
i say the itr ones are the best for the price. You can find them all over the place also they if i was gonna change to anything else i would use different cams also..or else it wouldnt be to worth it
Old Jan 31, 2005 | 02:43 PM
99 TYPE R's Avatar
I would say omni power, im gonna swap out my skunk2's for omni's springs
Old Jan 31, 2005 | 03:44 PM
Default Re: (99 TYPE R)
why the swap. are you not happy with the skunk2. ive been reading alot about the omni power and they look to be the better choice for me.
Old Mar 19, 2005 | 10:08 AM
tRex99's Avatar
Default Re: (screaminvtec)
i have a 94 gsr and have ctr intake cam and itr exhaust. i GUESS im gonna go ahead and buy some itr valve springs or something. what kind of retainers do i get? can i use stock gsr ones? or will itr ones fit on the valve?
Old Jul 23, 2005 | 06:47 AM
paopao's Avatar
Default Re: (tRex99)
Honestly, I don't really see the need to upgrade to stiffer valvesprings if you keep the stock rev limit. Don't get me wrong, if you can afford the valvesprings, go ahead and buy them. But from personal experience, I've ran Skunk2 Stage 2's on the stock GSR valvetrain for 4 months not reving past 8k w/no problems.
You might be saying "Well you're stupid for doing that" yes, I know this isn't a good idea, but I've had Portflow inners w/Skunk2 outers also running Skunk2 Stage 2's in a B18C1 and power started dropping off at 8400 RPM. The reason people get valve float and broken valves are because of driver error. Revving your motor to 9500 RPM is nothing but trouble especially when you're not making any power up there.
Moral of the story is to buy the valvesprings if you can afford. If not, don't get rev happy.
Old Jul 23, 2005 | 10:50 AM
8krdline's Avatar
I agree. I have a set of CTR cams about to go in and originally had ITR valvetrain. I sold the itr valvetrain for omni's just to have stiffer springs with the possibility of upgrading the cams later also.
white_n_slow
Jun 26, 2005 01:49 PM
HOND PWR
Sep 1, 2002 07:23 AM
EF'n
Apr 9, 2002 06:59 PM
StinkyTofu
Feb 8, 2002 10:17 AM
AfEn808
Dec 11, 2001 09:28 AM
