Problems with dpfi to obd1
Hey everyone. I am just finishing a swap on my 89dx hatch. I have converted all the way to obd1 and I am having problem getting it started. without the main relay the car turns over fine. When i put the relay in and try to start and and it it turns over starts for a brief second and the starts backfiring gas/smoke out the intake. . timing marks haven't been touched since swap so I know the are correct. search is not working but I belive it goes
34
12
"edit" firing order is correct
any advice will help. When it starts(but quickly dies) i do get a CEL 41 for the o2 sensor but nothing else.
Modified by 4potnick at 11:47 PM 1/30/2005
34
12
ok. getting cel's
4 CKP - crank position sensor (edit) "was backward" fixed
14 IAC (EACV) - idle air control valve (edit)"wrong plug" fixed
Off to check my notes. anyone with some help?
Modified by 4potnick at 11:49 PM 1/30/2005
ok. I got all the sensors figured out. no more cels but when you try to start it it just backfires throught the intake. I am starting to believe that knowone really cares to help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick »</TD></TR><TR><TD CLASS="quote">lost is me</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick »</TD></TR><TR><TD CLASS="quote">any help with how to test distributor or injectors, please.</TD></TR></TABLE>
Your firing order is right but the plug wires are out of phase. Put your motor at TDC, and take the distributor cap off, and you'll see where plug wire to cylinder 1 is supposed to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">Your firing order is right but the plug wires are out of phase. Put your motor at TDC, and take the distributor cap off, and you'll see where plug wire to cylinder 1 is supposed to go.</TD></TR></TABLE>ok. will check. I am pretty sure it is something with the ignition
In the little pictogram that you made in your 1st post, you should have #1 where you show #3, and then the order that you showed (1-3-4-2), I think!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick »</TD></TR><TR><TD CLASS="quote">firing order is correct.</TD></TR></TABLE>
And it still doesn't work? Whose OBD0 to OBD1 adapter did you use?
DelSlowmo
Mar 13, 2010 11:00 AM
PM-Performance
Jan 12, 2004 08:03 AM
