quick question all b series vtec crank seals and oil pump o rings interchangeable
I have a 94 jdm gsr block that i refreshened. I'm running an OBD2 ITR oil pump and i have a bottom end gasket set from a 00 B16a2 that was given to me. Is the 00 B16a2 rear main seal similiar to the 94 gsr rear main seal? Also will the 00 B16a2 oil pump o ring work on the 00 ITR oil pump? Thanks
Ls_V_TurboSi
May 10, 2006 05:14 AM
