Base Timing
Old Jan 30, 2005 | 07:41 AM
GsRHatchy1320's Avatar
Default Base Timing
I wrote this question before but in the wrong forum. I wanted to know What is the base timing for a 94 Gsr? and How do you set it?
Old Jan 31, 2005 | 07:14 AM
JimBlake's Avatar
Default Re: Base Timing (GsRHatchy1320)
Probably 16 (+/-2) degrees BTDC. Warm up the engine completely, jumper the SCS connector, make sure the idle is OK (800rpm or whatever?). Shine a timing light at the crank pulley. The set of 3 marks is all you need; they're already at the right position. Loosen the distributor mounting bolts & twist the distributor to make it right, tighten, & verify it's still OK.
91smashbox
Feb 11, 2008 01:33 PM
brusk13
Jan 11, 2006 07:01 PM
nsxblueteg
Jun 3, 2003 01:20 PM
rioninja
Aug 4, 2001 05:48 AM
BABY NSX
Jun 15, 2001 07:47 AM
