rpm/tach needle bouces when the car is cold....help please..
im trying to figure out why my tach needle on my 91 crx si is bouncing/flickering when the car is cold....can anyone help in diagnosing this...thanks
Jeff
sc300turbo@aol.com
Jeff
sc300turbo@aol.com
You could have a loose/bad electrical connection. Since your in Miami, I can lend you a hand if you need one.
it pretty much bounces everywhere.....at idle...low rpm and up high......car is completly stock.......is there any place i should look for a loose ground or connection?....thanks
It's probably your igition coil. Had the same problem a while back replaced it and the problem went away, just don't buy from Advance Auto because I went through about 6 of theirs before giving up and going elsewhere.
really?...did you have any other symptoms?....what exactly did you tach do?...as far as the bouncing?..did the car drive fine?...thanks
Jeff
Jeff
i just replaced the cap and rotor since they were a lil worn..and swapped in a new ignition coil.....and like magic the needle has stopped bouncing...thank you very much for your assistance...you saved me alot of time.....i really appreciate it
Jeff
Jeff
Tr0LL
Jun 29, 2003 09:24 AM
