HELP! Trunk light staying on all the time...
My dash trunk open indicator came on, but the trunk was closed. I folded down the rear seat and the interior trunk light is on and won't turn off. I pulled the light housing out and there's no relay. I checked all the fuses and nothings blown. I pulled the bulb out, but the trunk open dash light is still on. Please help. Thanks in advance.
Well I'm looking at the helms manual and even though I don't read circuit diagrams too well it looks like it is something at your thrunk latch switch. The only thing in the circuit is the trunk indicator light and trunk light. So these will turn on and off depending on the trunk latch switch. if the switch is closed then that means the trunk is open and if the switch is open then the trunk is closed. So your switch is closed all the time. Maybe you can check it and see what is wrong. That is about as much light as I can shed on the problem. Can anyone else help? If you have the Heml's it on page 23-182 and 23-183.
62maxx
Jul 25, 2011 09:36 AM
lpdrumer
Feb 20, 2011 04:25 PM
