96JDM ITR 4 by 114 disk brake conversion into EK
first question
does it fit into EK?
some people say it will not fit into EK
second question
can i keep my aftermarket EK shock and spring with ITR conversion?
or should i buy new Teg or EG shock and spring?
plz help me
thanks...
second question
plz help me
thanks...
If you just swap over the brakes, you can use your EK struts. If you swap everything, ie LCAs, then you'll need ITR struts.
one that i am going to buy is from JDM B16 EG HB
and i don't know what kinds of parts i can use.....
like ...
can i use my EK LCA with ITR conversion...?
also
passwordjdm.com says
This setup uses ITR calipers and GSR sized rotors. 4x114 pattern. Direct fitment with B-series axles.
i have D16... will it work?
thanks..
plz help....
like ...
also
thanks..
plz help....
