Can I UPGRADE my power cables?
As title says.....
I was wondering, if there is any advantage to changing my red/positive battery cables? You know, like you do your grounds.
Would thicker cables do me good? or bad?
Thanx in advance!
Thanx in advance!
clean the termal up is not and issue i upgraded my power wire when i did my battery relocation the power to the fuse box i upgraded to 8 gauge and from the alt to fuse box i upgraded it to 4 gauge. the wire to the trunk is 0 gauge. and the ground is 0 gauge to the trunk ,i grounded to the block and head then to the trunk for better ground the alt is also tapped into that ground wire .
It's never a bad thing to replace "up to" 20 year old wires. I know I did. Did I notice a difference? Not really, but will I have to replace them for another 20-30 years......NO WAY!!! And yeah, I upgraded to a larger gauge wire and added a couple of block grounds.
https://honda-tech.com/zerothread?id=1129736 ..............................................
94 accord typeR
Audio / Security / Video
12
Aug 27, 2014 03:23 PM
1991civicb16
Jul 12, 2011 07:20 PM
