swap info from GSR to LS
Old Jan 29, 2005 | 09:46 AM
nitelifegod's Avatar
Default swap info from GSR to LS
i searched coulnt find good answers,
I have a 1995 civic ex with a 1999 b18c1 swap, dropped a valve, destroy the b18c1
I'm going to swap a 1995 ls b18b(bougth car at auction for $200)
the car is automatic
will I be able to start the LS with the P72(or could i used the auto LS computer)?
will my gsr dizzy work with the LS computer?
any info on this swap will help?
thanks in advance
Old Jan 29, 2005 | 09:49 AM
jspresso's Avatar
Default Re: swap info from GSR to LS (nitelifegod)
cant use an auto ecu with a manual ahit wont work and the dizzy should work but why would you swap
Old Jan 30, 2005 | 01:24 AM
Default Re: swap info from GSR to LS (jspresso)
can I use the P72?
Old Jan 30, 2005 | 01:52 AM
albert's Avatar
actually I did a auto to stick swap on my civic went from sohc to b18c and swapped everything but the ecu so i was running a auto p28 until I found the p72
so you can use a auto ecu on standard
Dc4Colin
Jun 18, 2015 02:30 AM
hasty91ef
Jun 28, 2011 10:56 PM
b18crx88
Feb 14, 2008 06:37 PM
jordan2305
Jul 14, 2007 10:22 PM
Smoking LS
Jan 26, 2004 04:35 PM
