cant get mah new motor started
Old Jan 29, 2005 | 07:32 AM
B16_sol's Avatar
Default cant get mah new motor started
so i jus did a rebuild on my b16 and right when finishing we tried to start it, at first it wouldnt crank then we traced all tha wires for tha starter and tha ground was all nasty, so we fixed it and got it cranking. after that we jus never got spark to tha plugs, pulled tha dizzy apart and all parts had power and it was a very clean dizzy, then i checked to see what codes it was tossing at it gave me a #15 ignition out put signal. we checked all tha wires for tha dizzy and everything was good and thats as far as i am now so i dont know whats goin on with it. does anyone what this problem comes from???
Old Jan 29, 2005 | 08:02 AM
B16_sol's Avatar
Default Re: cant get mah new motor started (B16_sol)
bump
Old Jan 30, 2005 | 10:37 PM
B16_sol's Avatar
Old Feb 4, 2005 | 05:21 PM
B16_sol's Avatar
i jus bought a new dizzy and still nuffin
Old Feb 4, 2005 | 05:32 PM
rasinhell's Avatar
Default Re: (B16_sol)
check the timing because this sounds all too familiar. same exact thing was happening to me but my timing was way off. prrs like a kitten now
Old Feb 5, 2005 | 09:49 AM
B16_sol's Avatar
well i tried a new ecu and nuthin checked all wires to tha harness of tha dizzy and all wires get voltage
Old Feb 8, 2005 | 03:54 AM
rasinhell's Avatar
make sure the crank thingy is timed correctly cuz that is the reason why my car wouldn't start.
Old Feb 8, 2005 | 04:06 AM
Turbo_Mike's Avatar
Default Re: (The-Beast)
Did you have the motor out?
Old Feb 8, 2005 | 04:51 AM
HybridVisions's Avatar
Take all your wiring out and do it all over again...make sure distributor is set right.
Old Feb 8, 2005 | 04:52 AM
Oh yeah..check for fuel.....see if fuel pump even comes on..if it does..check fuel lines.
Old Feb 8, 2005 | 08:52 PM
Turbo_Mike's Avatar
Default Re: (HybridVisions)
Check your grounds, especially your thermostat!!11
Old Feb 8, 2005 | 08:56 PM
Donkey85's Avatar
Default Re: (razor ron)
yes, that is a very important ground and vital to not allowing the rig to start
Old Feb 9, 2005 | 08:58 PM
B16_sol's Avatar
it turned out to b a dead wire in tha harness runs like a beaut
Old Feb 9, 2005 | 08:59 PM
B16_sol's Avatar
thx for tha help ^_^
Hey_T
Nov 14, 2009 08:58 AM
408wdy
May 12, 2007 01:29 PM
ek4__
Oct 9, 2006 02:48 PM
GSlowR
Dec 7, 2004 07:38 PM
importlegions
Jul 29, 2004 11:28 AM
