2 Codes after Going boost
Old Jan 28, 2005 | 11:07 PM
sohcvtec1995's Avatar
Default 2 Codes after Going boost
I have also posted this in the Forced Induction forum, cause i really need an answer
3 MAP - manifold absolute pressure sensor
8 TDC - top dead centre sensor
Got these two codes after going boost. Dnt know why. I know that code 8 is in the dizzy, but what i dnt know is how to fix them. Did the sensors go bad or is it cause of the boost? Car is a 95 honda civic ex with a d16z6 in it if that helps
Modified by sohcvtec1995 at 4:02 AM 1/29/2005
Old Jan 28, 2005 | 11:25 PM
Revolver's Avatar
Default Re: 2 Codes after Going boost (sohcvtec1995)
I know it's a little early for a bump but, we want to try and get this figured out.
Old Jan 29, 2005 | 05:32 AM
BlackOnBlackTeggie's Avatar
Default Re: 2 Codes after Going boost (Revolver)
im geussing you dont have a missing link, if you dont thats why you are geting that Map code , but the top dead center code i dont know , the sensor is in the dizzy, so try a buddys dizzy and get a missing link
Old Jan 29, 2005 | 06:16 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: 2 Codes after Going boost (BlackOnBlackTeg)
yea.. def a missing link on the map code... you can use a missing link or check valves...
Old Jan 29, 2005 | 12:24 PM
Default Re: 2 Codes after Going boost (kKdARIAN)
Its a z6 with 450cc dsm's. Running the afc hack. Dnt have any check valves, or a missing link. But today i drive the car and it has no cell's and is running fine. Still got some smoke coming out the back but other than that it seems fine. Me and Slammed Sol played witht he timing and the fuel it is seems ok for now. Also we were trying to do a uberdata chip and for some reason my ecu is not likeing it. I have a p28 ao2 and he has a p28 aoo. Is there a difference?
Old Jan 29, 2005 | 12:49 PM
vtec69's Avatar
how much boost you running?
Old Jan 29, 2005 | 05:28 PM
Default Re: 2 Codes after Going boost (vtec69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">how much boost you running?</TD></TR></TABLE>
7psi, nothing big.
Devo94ac
Mar 10, 2008 04:28 PM
D16-t_coupe
Dec 2, 2007 04:19 PM
elpiar
Mar 22, 2005 06:02 PM
Bspec18
Mar 26, 2003 11:04 PM
01ITR#700
Mar 4, 2003 12:17 PM
