6 puck or 4 puck
Old Jan 28, 2005 | 11:03 PM
jscblulu's Avatar
Default 6 puck or 4 puck
hey what is the diff. btwn the 6 and 4 puck clutch? which would be better for a daily driver. car is a prelude sh 01 . need to know asap
Old Jan 29, 2005 | 12:59 AM
rice killer's Avatar
Default Re: 6 puck or 4 puck (jscblulu)
6 puck Un-sprung Disc. It is not designed for your daily driver car. When using an un-sprung clutch, you will probably experience moderate chatter. You should be prepared to hear your passenger complaining about the whiplash he or she will get every time you pull away from a light. While it will handle extreme aggressiveness, it is either engaged or disengaged with no ability to ease into the clutch. Its optimum use is designed for rally racing
for me i use a sock brute force clutch...that holds up pretty dam well...and it jus hit mearly 125 on the price....and i have about 160 whp...so idk is it worth the 500 bucks for a act or clutchmasters? no not really unless uv'e got sum major ponies to be laid down
Old Jan 29, 2005 | 03:07 PM
jscblulu's Avatar
thanks
Old Jan 29, 2005 | 10:22 PM
SJcivic's Avatar
Default Re: (jscblulu)
springs are there for vibration dampening... pucked clutches are GRIPPY.
Rich
Old Jan 30, 2005 | 06:15 AM
NJIN BUILDR's Avatar
As grabby as the six puck is the four puck is worst.
Glenn
Old Jan 30, 2005 | 08:10 AM
Rod.'s Avatar
Default Re: 6 puck or 4 puck (NJIN BUILDR)
<--- still getting use to the 6-puck
Old Jan 30, 2005 | 10:32 AM
PrettyLude's Avatar
its not that hard to drive, just takes a little getting used to
Old Jan 30, 2005 | 10:58 AM
d15nonvtec's Avatar
Default Re: (PrettyLude)
i used to have the act 6 puck in my daily driver, i got used to it and actaully liked it, but it did wear out prematurely and i replaced it with a street/strip disc
92_boosted
13
Jul 5, 2007 04:58 PM
wenlyone
Jul 23, 2004 02:27 PM
GsR HtCh
33
Nov 20, 2002 09:45 AM
4doorH22
Sep 14, 2001 08:55 PM
