Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Wide Accord Wheels?
Old Jan 28, 2005 | 10:13 PM
EkDave's Avatar
Default Wide Accord Wheels?
What is the widest tire size or rim that can fit onto a 2004 Accord 4 door? Will the Acura TL A-Spec Wheels fit?
Old Jan 29, 2005 | 07:14 AM
VtecSpool's Avatar
Default Re: Wide Accord Wheels? (EkDave)
TL wheels 02-04 will fit the v6 model accord since it has a 5x114.3 bolt pattern. It looks hot, I've seen it before
Old Jan 29, 2005 | 08:05 AM
Juccord's Avatar
Default Re: Wide Accord Wheels? (VtecSpool)
does anyone know how wide a tire you can put on a 02 sedan..? (front and back)
Old Jan 29, 2005 | 08:12 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: Wide Accord Wheels? (Juccord)
i'm running 225/40/18 with no problems.
Old Jan 29, 2005 | 12:37 PM
iam7head's Avatar
Default Re: Wide Accord Wheels? (-Bionic-)
generially speaking 8inch wide should clear most brake hub
i know it's bitchin' to have a wide *** rear wheel but..understeering to FWD car=
newer accord and TL wheels will fit(five lugs to five lugs)
Old Jan 30, 2005 | 01:24 PM
Juccord's Avatar
Yah, im running 225/40/18 right now also, but I wanted to go 245/40/18 in the front and 235/40/18 in the back, I dunno if its possible, if not id like to do 235 on both, if anyone knows, let me know what the widest that anyone has done without any problems. thanks
Old Jan 30, 2005 | 01:45 PM
ricepicker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Juccord &raquo;</TD></TR><TR><TD CLASS="quote">but I wanted to go 245/40/18 in the front and 235/40/18 in the back</TD></TR></TABLE>
Why do you want staggered wheel sizes from front to back? So you get a bigger patch of rubber every 7k miles before you rotate them to the smaller width tires?
Old Jan 30, 2005 | 05:04 PM
Default Re: Wide Accord Wheels? (ricepicker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricepicker &raquo;</TD></TR><TR><TD CLASS="quote">
Why do you want staggered wheel sizes from front to back? So you get a bigger patch of rubber every 7k miles before you rotate them to the smaller width tires?</TD></TR></TABLE>
wouldnt be able to rotate them front-back, only left-right.
btw, i have 235/40-18's on 18x7.5's with a +45 offset. i havent had it rub a single bit and i also think that the offset could be lower because it seems like theres plenty space between the suspension and tire.
Old Jan 30, 2005 | 05:55 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: Wide Accord Wheels? ("Hites")
With that setup does the tires poke out/come out of the fender?
Old Jan 31, 2005 | 05:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- &raquo;</TD></TR><TR><TD CLASS="quote">^^^^
by my eye, it seems to be flush but if any pokes out, id say maybe 1mm.
Old Jan 31, 2005 | 08:08 AM
Juccord's Avatar
Have you lowered your car??
I know on mine that if I had them "poking" out they would be rubing the fender.
Is ther any Noticable difference in performance by going from a 225 to a 235, or does it have to be more of an increase to be able to notice? I just need new tires, I blew one in the fall right before I put my car away. thanks
Old Jan 31, 2005 | 08:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Juccord &raquo;</TD></TR><TR><TD CLASS="quote">Have you lowered your car??
Is ther any Noticable difference in performance by going from a 225 to a 235, or does it have to be more of an increase to be able to notice? I just need new tires, I blew one in the fall right before I put my car away. thanks</TD></TR></TABLE>
im planning on lowering my car 1". cant tell ya the different from a 225 to a 235 since ive never owned 225's. ive only owned 205's, 235's, 245's, and 275's.
Old Feb 5, 2005 | 06:52 AM
Juccord's Avatar
did you notice a difference btween 235 and 245?
I just wanna know if its worth the extra 60 bucks a tire.
Ive always had 225's and ive always been happy with them, but if its worth it, then ill try alittle bigger.
Old Feb 5, 2005 | 07:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Juccord &raquo;</TD></TR><TR><TD CLASS="quote">did you notice a difference btween 235 and 245?
Ive always had 225's and ive always been happy with them, but if its worth it, then ill try alittle bigger.</TD></TR></TABLE>
i had the 245's on the front of my sc400 with 275's out back. thing handled great even though it was a porker at ~3600lbs. of course, bigger meats in the back induces understeer. honestly, i cant tell you if there was or wasnt a difference because the tires were/are on 2 different vehicles; sorry.
akronym
Honda Accord 2016- 2017
Jun 27, 2019 10:34 AM
Serstylz2
Feb 27, 2012 02:18 PM
yanin_flo
Jun 22, 2006 09:00 AM
essex
May 18, 2005 12:28 PM
LiKe_WhOa!
Jan 28, 2005 12:58 AM
