Can someone identify these Si motor mounts? What else do i need for a B-Series Swap into EK
Old Jan 28, 2005 | 05:50 PM
SyDuck's Avatar
Default Can someone identify these Si motor mounts? What else do i need for a B-Series Swap into EK
gathering parts for b-series into ek swap. some guy is selling me his mounts that he replaced with hasport mounts.
can someone identify these mounts? (rear tranny mount, mount under cam gears etc etc)
heres what i need:
1. bracket under cam gears: get one from an 99-00 civic SI
3. rear mount under intake mani: you need one from a 99-00 civic SI (bracket that is shaped like a T
5. side tranny mount: you'll need one from a b-series motor
here's what i am getting:
what additional mounts/brackets do i need. i am aware i still need the tranny bracket (t-shaped). anything else?
Old Jan 28, 2005 | 06:06 PM
Gump's Avatar
Driverside (top of picture) mount is same on all EK's. You still need passenger and driverside torque mounts.
Old Jan 28, 2005 | 06:08 PM
SyDuck's Avatar
Default Re: (Gump)
hm..
i found #1 and 3.
whats #5?
Old Jan 28, 2005 | 06:09 PM
chad's Avatar
Moderator
Default Re: (SyDuck)
USE YOUR D SERIES MOUNTS.....use B series brackets!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!
Old Jan 28, 2005 | 06:10 PM
getnasty's Avatar
Default Re: (chad)
damn im doing this tommorow and those dont look like my mounts
Old Jan 28, 2005 | 06:14 PM
Gump's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SyDuck &raquo;</TD></TR><TR><TD CLASS="quote">hm..
i found #1 and 3.
whats #5?</TD></TR></TABLE>
These are all the mounts you need, the torque mounts parts are 1, 11, 9, and 8, 12, 10, and all the bolts and washers too.
Old Jan 28, 2005 | 06:52 PM
B18ek's Avatar
Default Re: (chad)
Well said
Old Jan 28, 2005 | 06:58 PM
Ivan's Avatar
senior gold member
Default Re: Can someone identify these Si motor mounts? What else do i need for a B-Series Swap into EK (SyD
hmm i did my swap a couple of years ago. I think I used my dseries trans bracket mount though. I'm not positive though. but you pretty much have what you need except for the torque mount brackets. you use those off a bseries but thats been said already.
Old Jan 28, 2005 | 06:59 PM
92eg6's Avatar
Default Re: (B18ek)
baisically use all ur stock MOUNTS and u need a 99-oo si/gsr/b-series del sol ac bracket, umm 99-00 si rear tranny bracket, and front tranny bracket
JDM son!
Mar 11, 2009 02:48 PM
99TurboBlue
Jul 9, 2007 05:07 AM
HB VTEC
Nov 24, 2006 07:40 AM
dc2drifterx
May 9, 2005 12:15 PM
Wazup
Nov 11, 2003 12:53 PM
