dx > ex cluster, check engine light?
Old Jan 28, 2005 | 05:05 PM
devils_civic's Avatar
Default dx > ex cluster, check engine light?
i swap clusters. dx to ex in my 97 hatch. when i had the dx cluster in, the light wasnt on, but when i put in the new one the light came on? what would make this happen? and how could i fix it?
Old Jan 28, 2005 | 05:10 PM
BlueIntegraBoy's Avatar
Default Re: dx > ex cluster, check engine light? (devils_civic)
Your DX cluster might have had a burnt CEL bulb. So you were probably running with a CEL for a while.
Old Jan 28, 2005 | 05:18 PM
sohcvtec1995's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devils_civic &raquo;</TD></TR><TR><TD CLASS="quote">i swap clusters. dx to ex in my 97 hatch. when i had the dx cluster in, the light wasnt on, but when i put in the new one the light came on? what would make this happen? and how could i fix it?</TD></TR></TABLE>
Pull the code and find out.
Old Jan 28, 2005 | 05:22 PM
pdiggitydogg's Avatar
http://www.hstuners.com/forums...23007
Old Jan 28, 2005 | 05:34 PM
99hatch's Avatar
Default Re: (pdiggitydogg)
that site is better than what we got on HT for checkin your own cel
Old Jan 28, 2005 | 06:14 PM
Thanks...I wrote it
Old Jan 28, 2005 | 09:41 PM
slipstream2005's Avatar
the reason your check engine light is on is because when u switched them out...the wiring hookups were not the same therefore causing an eclectrical problem back to your ECU and then causing the check engine light to come on
Old Jan 29, 2005 | 05:12 AM
uh...no........youre wrong sir
Old Jan 29, 2005 | 07:13 PM
yeah, thanks for the info pdiggity. seems like im throwing a code 41, o2 sensor. this is gay.
runawayboy
Sep 20, 2007 09:19 AM
tonysenese
May 21, 2007 07:46 AM
LwdJdmR
15
Apr 18, 2007 11:51 PM
SiLuck2
17
Jan 28, 2006 08:19 PM
cdakidd03
Dec 3, 2005 09:26 AM
