Reset ECU after CEL without fixing problem
So my CEL came on two weeks ago. I jumped the service connector and it indicated Code 67 Catalyst low efficiency. (same as P0420). I remembered the time it came on, I drove over a tiny bump on the freeway and the CEL came on, so I figured MAYBE, because of a bump, the CEL came on by mistake.
So, just to really see if the CEL will come on again, I reset the light. I've driven 800 miles or so since I reset the light. The CEL hasnt come back on. I did an oil change and the car runs smooth as it has since I got it a couple of years ago.
Has this happened to anyone before? Is it ok? Will the CEL come on again if it sees a problem?
I have the same problem as you. If I reset the ECU the code will still come back on. The reason being is that I have a test pipe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam P 27 »</TD></TR><TR><TD CLASS="quote">If my code was coming back, I'd see there is a problem.
The problem is... the code isnt coming back.</TD></TR></TABLE>
Then there isn't a problem.
I would just wait until it comes back (if it comes back at all) to take any action at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio »</TD></TR><TR><TD CLASS="quote">bring it in to a shop</TD></TR></TABLE>
Thats why I ask here and see what people's thoughts are before I cough up the cash to get it even checked.
I figure I'll wait till it comes on again. Doesn't the ECU check three times (read this when I searched) before the CEL is displayed? If so, the CEL SHOULD come back on depending on the intervals the ECU checks.
**** if I know what I'm talkin about but I hope you get it.
Thanks for the replies guys.
skaternak
12
Aug 13, 2009 08:39 PM
b20vtech
19
Feb 6, 2009 08:21 AM
