Drain Bolt...
Old Jan 28, 2005 | 01:38 PM
Mario.'s Avatar
Default Drain Bolt...
So I bought my car, and the guy wasn't using a reservoir for the overflow and left the drain bolt cracked open.
That gold bolt there... I tried using a ratchet on it with the header on and it was a pain. So my question: what should I do with it? Take the header off and try an impact? Is it possible to strip this out?
Help !!
Old Jan 28, 2005 | 01:40 PM
Dan GSR's Avatar
Default Re: Drain Bolt... (Mario.)
what are you trying to do? take it off or put it on?
I usually use a big *** breaker bar , and it comes off with a little effort
Old Jan 28, 2005 | 01:42 PM
Chiovnidca's Avatar
Is it leaking? A socket and breaker bar should get it loose.
Old Jan 28, 2005 | 01:50 PM
Mario.'s Avatar
Default Re: Drain Bolt... (Chiovnidca)
It is open right now. When the car would usually dump fluid into the reservoir, it dumps it out that opening instead.
So a socket and a breaker bar... is it necessary to take the header off?
Old Jan 28, 2005 | 02:20 PM
AWDxBOOST's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario. &raquo;</TD></TR><TR><TD CLASS="quote">It is open right now. When the car would usually dump fluid into the reservoir, it dumps it out that opening instead.
So a socket and a breaker bar... is it necessary to take the header off?</TD></TR></TABLE>
itd be a lot easier
Old Jan 28, 2005 | 03:11 PM
Chiovnidca's Avatar
no
arielb1
Dec 18, 2019 11:39 AM
LAOS
Nov 16, 2005 09:40 PM
stolenhubcabs
Dec 18, 2003 07:09 PM
cruzersi99
Sep 25, 2003 08:02 PM
EF_LSVtec
Oct 3, 2002 06:30 AM
