Drain Bolt...
Drain Bolt...
So I bought my car, and the guy wasn't using a reservoir for the overflow and left the drain bolt cracked open.
That gold bolt there... I tried using a ratchet on it with the header on and it was a pain. So my question: what should I do with it? Take the header off and try an impact? Is it possible to strip this out?
Help !!
Help !!
Re: Drain Bolt... (Chiovnidca)
It is open right now. When the car would usually dump fluid into the reservoir, it dumps it out that opening instead.
So a socket and a breaker bar... is it necessary to take the header off?
Re: Drain Bolt... (Mario.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario. »</TD></TR><TR><TD CLASS="quote">It is open right now. When the car would usually dump fluid into the reservoir, it dumps it out that opening instead.
So a socket and a breaker bar... is it necessary to take the header off?</TD></TR></TABLE>
itd be a lot easier
itd be a lot easier
no
no
arielb1
12-18-2019 11:39 AM
