cp pistons with eagle H-beam rod ?
Old Jan 28, 2005 | 01:01 PM
boost fed ls's Avatar
Default cp pistons with eagle H-beam rod ?
I was wondering if you have to mod eagle h-beam rods to accept cp pistons wrist pins? The guy that is helping me build my motor mentioned that you had to have a special rod bushing to accept wrist pins that were not press fit.
Old Jan 28, 2005 | 01:11 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
interested bump
Old Jan 28, 2005 | 01:39 PM
Pandahatch's Avatar
Not that I know of, I have CPs with Eagle H beams in my car. I know if you're using a stock rod or piston the have to be modified but not for this.
Old Jan 28, 2005 | 05:38 PM
T4eg's Avatar
Default Re: cp pistons with eagle H-beam rod ? (boost fed ls)
You shoudnt have any problems?
Chris
Old Jan 28, 2005 | 08:42 PM
MugenRacerX's Avatar
Thats also the combo im gonna be running should"nt be a problem.
Old Jan 29, 2005 | 04:20 AM
Default Re: (MugenRacerX)
ok thanks, so the people that are using eagle rods and cp pistons just pushed the wrist pin in and c-clipped them?
DntFk_jdm
Engine Machining & Assembly
17
Mar 1, 2016 07:23 PM
kpjo4
Mar 11, 2010 07:56 PM
d16dcoe45
Sep 27, 2006 05:15 PM
SiR99
Sep 1, 2006 09:17 PM
