Q about tire PSI for yoko es100
Old Jan 28, 2005 | 01:24 AM
.water's Avatar
Default Q about tire PSI for yoko es100
i checked my tire today. psi was around 30ish..this is 1st time i checked after i got new tires (yokohama es100 195/55/15) if u own this tires. what is the right tire PSI? is it 45 just like stock PSI? or something else? thanks
Old Jan 28, 2005 | 01:29 AM
soundbomber's Avatar
Default Re: Q about tire PSI for yoko es100 (Chris DC2)
45 is ******* high as ****, highest i'd go is like 40, 38 sounds good
Old Jan 28, 2005 | 01:33 AM
drunknbass's Avatar
Default Re: Q about tire PSI for yoko es100 (soundbomber)
depends on the tire.. 45 psi is normal for some tires.. gotta check the sidewall and see the specs
Old Jan 28, 2005 | 01:35 AM
ErrDizzle's Avatar
i usually set mine at max pressure when the tires are hot. when cold, like 15% below max.
Old Jan 28, 2005 | 01:46 AM
YEE*MagicEK20kombobomber's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">45 is ******* high as ****, highest i'd go is like 40, 38 sounds good</TD></TR></TABLE>
my pirelli`s say 51psi., i have em at 40
the correct tire pressure should be written on the sidewall somewhere.
Old Jan 28, 2005 | 02:11 AM
The_Todd's Avatar
Farts in the shower
And this is in a/c why.......
check your sidewall or talk to your tire guy .
Old Jan 28, 2005 | 12:26 PM
.water's Avatar
oh iam sorry..i typed wrong..lol not 45 ..stock psi is 35..haha soo..go for 35 psi??
Old Jan 28, 2005 | 12:44 PM
jdmd's Avatar
my sidewalls say 50 psi. my tire size is 225/45/16, so it may be different. i keep mine at 40 psi though. but i suggest going out reading your sidewall and fill tires accordingly. usually keep it a few psi under what it says on the sidewall.
Old Jan 28, 2005 | 02:00 PM
.water's Avatar
anyone else fo sure?
Old Jan 28, 2005 | 02:07 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 &raquo;</TD></TR><TR><TD CLASS="quote">anyone else fo sure?</TD></TR></TABLE>
all tire PSI`s are different so your stock PSI wont be the same. why dont you just check the sidewall to be sure?
Old Jan 28, 2005 | 02:10 PM
.water's Avatar
Default Re: Q about tire PSI for yoko es100 (D6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D6 &raquo;</TD></TR><TR><TD CLASS="quote">
all tire PSI`s are different so your stock PSI wont be the same. why dont you just check the sidewall to be sure?</TD></TR></TABLE>
why is that? i mean tire is 195-55-15 just like stock tire size..so PIS wouldnt be same?
Old Jan 28, 2005 | 02:11 PM
babietuan323's Avatar
i've got 195/50/15 avs es100 and i inflated them to 38psi recommended
you should call the tire guy and see what they say
Old Jan 28, 2005 | 02:13 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 &raquo;</TD></TR><TR><TD CLASS="quote">why is that? i mean tire is 195-55-15 just like stock tire size..so PIS wouldnt be same?</TD></TR></TABLE>
nope, PSI`s wouldnt be the same. different tire compunds, different layer construction, and other variables means a different PSI
Old Jan 28, 2005 | 02:32 PM
Ek9ReVciVic's Avatar
i go 40 psi on my yok's...make sure i dont bend a rim...
Charri
Jun 23, 2005 01:57 PM
dgrave
Dec 19, 2004 09:26 PM
HondaGus
May 21, 2004 11:54 PM
adrian1281
Jun 28, 2003 08:39 AM
B_1_8_hatch
39
Dec 8, 2002 06:36 PM
