tire wear
wat can i do to stop the inner wearing on my 17's, the car is lowered and i am not to sure how low it is , it was lowered when i got it. It has to be lowered a lot considering the 17's are up in the rear wheel wells a little bit, and there are no wheel gaps in the front fenders. What can i do other than purchasing a camber kit, if there is anything to do.
get a camber kit...they might be hard to install but it saves the money you would be spending on new tires.
unless you get those cheap "big o" brand tires, then you could just buy those everytime you need new tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR5sARECOOL »</TD></TR><TR><TD CLASS="quote">get an alignment</TD></TR></TABLE>
do this i dropped my car 3 inches....with a camber kit....went through 2 brand new tires in 4 months...got new tires..got an alighnment...car rides much better drives much better handles way better...get it as soon as you can.
camber kit and alignment...done deal.
don't know which camber kit... go with Ingals or SPC... SPC comes highly recommended by many HT users. search for SPC and you'll get alot of topics about it.
Tire wear on the inside shoulder is caused by toe-out. Take your car to an alignment shop and have them set the toe to factory specification.
Depending on the type of rack they have, you will probably have to remove your front bumper to get the car on the alignment rack, and to have line-of-sight for the optical sensors.
