Engine Problems
Old Jan 14, 2002 | 05:10 AM
Spartanic's Avatar
Default Engine Problems
Alrighty people I have a problem with my engine. When I start my car I can hear the engine cranking but the engine does seem to ignite the fuel and air mixture, so I'd be cranking it for a while with no response and at the same time I can hear this strange noise like something grinding. I think that sound may be the new water pump that I had just got done installing so maybe it needs some breakin in. Also this problem started after I installed the water pump. Geez, I hope I didn't just install a defective water pump cause I heard It'll make a whirlling sound when its broken.
Old Jan 14, 2002 | 07:22 AM
Crazydave's Avatar
Default Re: Engine Problems (Spartanic)
the water pump shouldn't effect your cars starting ability..
you might however have jumped a tooth on your timing belt.. make sure that you installed your timing belt correctly and double check your spark plugs
Old Jan 16, 2002 | 06:06 AM
deepnite's Avatar
Default Re: Engine Problems (Crazydave)
dont know if u install d the pump urself..but if a reputable shop did it..it should be OK...the the grinding sound seems to be the starter..recheck ur connections..might be a ingnition problem..does not mean u need new parts though
Old Jan 16, 2002 | 08:22 AM
garagespecial
Guest
Posts: n/a
Default Re: Engine Problems (deepnite)
check your cap and rotor
yob
Mar 28, 2019 10:52 PM
GoodEyeSniper
Apr 10, 2010 04:28 PM
fryman
Aug 22, 2008 10:31 AM
90YellowRex
16
Mar 9, 2006 11:13 AM
blacksoul
23
Aug 9, 2002 08:22 AM
