Custom ITB, Which are best/easiest to work with
Old Jan 27, 2005 | 04:39 PM
b20ek's Avatar
Default Custom ITB, Which are best/easiest to work with
I am interested in experienced peoples opinions on DIY throttlebodies. Which are easiest and most effect. Also will '98 CBR 900rr throttle bodies work and what size are they if anyone knows. Thanks.
Old Jan 28, 2005 | 06:53 AM
machine4321's Avatar
if your going for most perfomance then i think the gsxr itb are the best to work with cause you can get a straight shot in to each cyinder
how ever the honda itbs are easier to get working with the stock honda ecu liek tps and what not
Old Jan 28, 2005 | 10:38 AM
RCautoworks's Avatar
Default Re: (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">if your going for most perfomance then i think the gsxr itb are the best to work with cause you can get a straight shot in to each cyinder
I know other people beleive that to, but check out the setup a customer brought in for me to do some work on. Pretty straight if you ask me.
Old Jan 28, 2005 | 02:32 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: Custom ITB, Which are best/easiest to work with (b20ek)
i am using the honda cbr929 ones. the tps is the same as the honda cars so you don't need to reclock them. straight shot in the cylinder also.
Old Jan 28, 2005 | 02:35 PM
Default Re: Custom ITB, Which are best/easiest to work with (EmotionIsDead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EmotionIsDead &raquo;</TD></TR><TR><TD CLASS="quote">i am using the honda cbr929 ones. the tps is the same as the honda cars so you don't need to reclock them. straight shot in the cylinder also. </TD></TR></TABLE>
But you do have to switch the 2 wires around.
Old Jan 28, 2005 | 03:03 PM
b20ek's Avatar
Default Re: Custom ITB, Which are best/easiest to work with (90blackcrx)
Thanks for the responses, keep 'em goin! What year throttle bodies are you guys using and what kind of engines do you have? Anyone wanna post there dyno?
Old Feb 13, 2005 | 07:47 AM
FormulaGSR's Avatar
so the 929 is the easiest to set up?
Old Feb 13, 2005 | 08:12 AM
prob;y the beasiest yes ...i wasnt thinking but im on a f20 (h22) and i had to space mine alot ...but that looks pretty dam straing
Old Feb 13, 2005 | 07:53 PM
Kendall's Avatar
Default Re: Custom ITB, Which are best/easiest to work with (FormulaGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FormulaGSR &raquo;</TD></TR><TR><TD CLASS="quote">so the 929 is the easiest to set up?</TD></TR></TABLE>
I actually prefer the GSXR 1000 setup due to the larger size throttle bodies and the ability to space the throttle bodies to get an equal length runner setup as opposed to the ever-so-common unequal length setup. The car will run alright with no tuning and the stock Suzuki TPS, however you will need to have your ECU tuned to compensate for the incorrect TPS voltage. Also, the stock fuel maps aren't near what they need to be, however you'll run into this problem with the CBR setup as well.
Old Feb 14, 2005 | 01:58 PM
FormulaGSR's Avatar
Default Re: Custom ITB, Which are best/easiest to work with (Kendall)
what is the size difference between 929rr, gsxr750 and gsxr1000 tbs. I heard the 750 & 1000 are the same from 01 up, is that true? How much power will each support? anyone know.
Thank you
Old Feb 14, 2005 | 02:24 PM
H23vtecEG's Avatar
for you DIY ladies out there check out my flange and runners also offer them welded. it will cut time and trouble, and very well priced. check out my sign or me
2000h
Apr 28, 2008 04:27 PM
96ej8MR
Honda S2000
Apr 16, 2007 09:51 PM
96ej8MR
Honda Civic (2006 - 2015)
15
Apr 15, 2007 03:35 PM
Azn Batman
Mar 8, 2006 01:01 AM
