Taking off flywheel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi »</TD></TR><TR><TD CLASS="quote">make sure u have the flywheel locked in place so it doesnt spin. get craftsman
Impact wrench ownz!!
</TD></TR></TABLE>Impact wrench ownz!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unsungsohc »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 »</TD></TR><TR><TD CLASS="quote">whats the easiest way to lock the flywheel?</TD></TR></TABLE>
Just have a buddy stick a crowbar or a screwdriver in one of the teeth to hold it still.
easy way to lock the flywheel jam a pipe on the tooth and prop it against the floor.
thats what i did after trying to jam it with a screw driver and the ******* thing sliped and my thumb got caught in the tooths split my nail real good lmfao
make sure you use thread lock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Special-Ed »</TD></TR><TR><TD CLASS="quote">
Do the flywheels need to be torqued down to a certain specification? If so, what spec?</TD></TR></TABLE>
Helms says 87 ft. lbs. on the flywheel and 19 ft. lbs. on the pressure plate
Use an impact. Won't turn. Craftsman sells electric impacts, which aren't as strong, but cheaper than buying an air impact and an air tank.
17 is what it is, and yeah its the higher number socket points. The good one
My dad was thinking the same thing when we did my car, i had to show him to ease his worries.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 »</TD></TR><TR><TD CLASS="quote">easy way to lock the flywheel jam a pipe on the tooth and prop it against the floor.
make sure you use thread lock</TD></TR></TABLE>
thanks for sharing...i hate blood!!
make sure you tighten the fly wheel kinda like a tire, tighten across and work around...
me and my buddy put a d15b in his 97ex and we didnt tighten the flywheel down to spec i guess, well 3 days later is fell off! we had to have the car towed
KrIzMoCRX
17
Mar 23, 2006 11:19 AM
