HELLLLLPPP!!!
Old Jan 27, 2005 | 02:28 PM
SlAmMeD 91 HaTcH's Avatar
Default HELLLLLPPP!!!
HEY GUYS I OWN A 91 CIVIC HATCH and at idle it idles like its missfireiing and when i look at the ecu it flashed 16times then did it 16times etc which is fuel injectors what is wrong the car drive fine when warm what could be the problem it is a daul point 1.5 95 cx motor...?????help 1 wire o2??help
Old Jan 27, 2005 | 02:48 PM
Perfectionist's Avatar
Default Re: HELLLLLPPP!!! (SlAmMeD 91 HaTcH)
You may get a better response by including your basic question in the title instead of just "HELLLLLPPP!!!" Something like "Code 16 and bad idle".
Some punctuation wouldn't hurt either.
Anyway, the ECU will set a code 16 when there is a break in the electrical circuit for the fuel injector system. Check all your injector clips, wire harness, and any other connectors for loose or damaged connections.
Another cause is the main relay.(A search will turn up a wealth of information about it) It provides power to the injectors. Another possibility is a bad injector coil. Check the cheap and easy fixes first before you start throwing parts at it.
CRX-CHACE
12
Jul 3, 2013 07:40 PM
lsvSwagg
Jan 29, 2013 07:46 AM
sakasaku
Aug 20, 2009 01:27 PM
Rad_Teg
Jan 25, 2005 06:02 AM
4ghatch
Jan 16, 2003 02:33 PM
