ECU code 16
Old Jan 24, 2005 | 11:22 AM
Rad_Teg's Avatar
Default ECU code 16
(Yes I have arlready searched and havn't found a specific answer.) I have a 93 integra gs. Recently my car has started throwing a code 16. Took out my integra manual and found out that the code was a fuel injection problem. I have narrowed it down to cylinder #3. I took out all the fuel injector harness plugs and all give me an electrical reading except for injector #3. What could be my problem? Could it be the ecu or just a bad ground somewhere?
Old Jan 24, 2005 | 11:40 AM
aznballer's Avatar
check for grounds first it will b cheaper to fix than gettin another ecu
Old Jan 25, 2005 | 01:00 AM
Rad_Teg's Avatar
Default Re: (aznballer)
Which grounds should I check?
Old Jan 25, 2005 | 06:02 AM
JimBlake's Avatar
Default Re: (Rad_Teg)
Are '93s the same as later ones?? Probably all injectors are supposed to get (+) battery voltage all the time (from the main relay). Check that by measuring to ground, don't measure between the 2 wires in the injector plug. The ECU closes the ground side of the circuit to fire the injector. If the (+) side is OK, then look for an open circuit in that other wire going to the ECU.
lsvSwagg
Jan 29, 2013 07:46 AM
Red_ED8
Jul 15, 2010 11:19 AM
CCCP-ef
Sep 13, 2008 06:11 AM
chivid
Sep 4, 2006 07:25 PM
allm0torGSR
Apr 30, 2004 05:10 PM
