What is this little "nozle"?
Old Jan 27, 2005 | 11:44 AM
VWkila's Avatar
Default What is this little "nozle"?
This is found at the neck of the top coolant hose.
It is not connected through the neck, meaning it's some kind of cap.
Anybody?
Modified by VWkila at 3:56 PM 1/27/2005
Old Jan 27, 2005 | 11:47 AM
sohcvtec1995's Avatar
Default Re: What is this little "nozle"? (VWkila)
I belive it is a pressure/air release valve.
Old Jan 27, 2005 | 11:50 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: What is this little "nozle"? (sohcvtec1995)
Correct. Bleeder valve.
Old Jan 27, 2005 | 11:57 AM
VWkila's Avatar
Default Re: What is this little "nozle"? (JDM_Ej)
When would I unscrew this valve? Seems like this is not an automatic valve.
Old Jan 27, 2005 | 12:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VWkila &raquo;</TD></TR><TR><TD CLASS="quote">When would I unscrew this valve? Seems like this is not an automatic valve.</TD></TR></TABLE>
Dnt know that one, but possibly when the car is running, but then there the risk of hott coolant getting on you.
Old Jan 27, 2005 | 12:16 PM
mwieczorek43's Avatar
When we swapped my Rex I did a coolant-flush. There were air-bubble in the system (probably b/c we suck).... That little bleeder-thing came in handy then.
And that was at idle-speed. I dont know if this'll help ?
Old Jan 27, 2005 | 12:38 PM
wilsel's Avatar
Default Re: What is this little "nozle"? (mwieczorek43)
When you've flushed your radiator, replaced the thermostat, or waterpump its necessary to bleed the air from the system after adding coolant again.
Old Jan 27, 2005 | 02:33 PM
jdmeg9's Avatar
Default Re: What is this little "nozle"? (wilsel)
yeah if you don't bleed it, it will overheat because of air in the line
Old Jan 27, 2005 | 07:11 PM
VWkila's Avatar
Default Re: What is this little "nozle"? (jdmeg9)
I need to tap a water temperature gauge sender some where. So would it be okay to put it in place of this valve?
Old Jan 27, 2005 | 07:21 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VWkila &raquo;</TD></TR><TR><TD CLASS="quote">I need to tap a water temperature gauge sender some where. So would it be okay to put it in place of this valve?</TD></TR></TABLE>
Yup. In the event of coolant replacment processes, just start your car cold with the radiator cap off. It will bubble itself out over time. You can squeeze hoses for added facility.
Old Jan 27, 2005 | 07:24 PM
dunkd's Avatar
yah a lot of people just ignore that bc sometimes it just snaps off causing one big mess... plus just takin off the rad cap is 10x easier
Old Jan 27, 2005 | 07:33 PM
hayabusa160's Avatar
Default Re: (dunkd)
so you just take the rad cap off and let it run right?
my car takes forever to get up to temp its pissing me off.
Old Jan 27, 2005 | 07:35 PM
snoochtodanooch's Avatar
bleeder
Maginnovision's Avatar
Take the rad cap off and let it run, but play with the rad hoses too, helps. You could also try moving the car up and down a little, makes things a little faster.
Old Jan 27, 2005 | 07:36 PM
dso's Avatar
dso
Default Re: (hayabusa160)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">
my car takes forever to get up to temp its pissing me off. </TD></TR></TABLE>
you might consider gettin a new thermostat then,just a thought
Default Re: What is this little "nozle"? (snoochtodanooch)
i have actually never bled a system from their, i will just burp it at the radiator and let the cap take care of the rest.
AtoZ
Jan 12, 2009 02:37 PM
93H22
Mar 21, 2008 11:26 AM
vtec.dc2
Oct 15, 2006 10:19 AM
coupon
Dec 11, 2004 04:36 AM
Mattyg2
Jul 21, 2004 12:31 AM
