CEL #43 with Walbro 255?
Old Jan 27, 2005 | 10:11 AM
_jester_'s Avatar
Default CEL #43 with Walbro 255?
i am now getting a CEL#43. Would this be because of a walbro 255 fuel pump?I
Any thoughts?
Modified by Xrated-Eg at 7:03 PM 1/27/2005
Old Jan 27, 2005 | 10:15 AM
Luserkid's Avatar
Default Re: CEL #43 with Walbro 255? (Xrated-Eg)
43 Fuel supply system
Bad fuel tank maybe? Try going back to stock and see if it goes away, if it does then its probably the fuel pump.
Old Jan 27, 2005 | 12:42 PM
_jester_'s Avatar
Default Re: CEL #43 with Walbro 255? (Luserkid)
It was in for a little while, then that and a 41CEL popped out of no where. Car idles kinda lumpy? I am baffled
Old Jan 27, 2005 | 12:55 PM
JDMisGOOD's Avatar
bad connection somewhere?
Old Jan 27, 2005 | 01:59 PM
platinum00's Avatar
Default Re: CEL #43 with Walbro 255? (JDMisGOOD)
i say bad connection. take a look at those, it could be a easy fix.
what is your rail pressure at. do you have a FPR..
should be around ~43psi
platinum.
Old Jan 27, 2005 | 03:02 PM
_jester_'s Avatar
Default Re: CEL #43 with Walbro 255? (platinum00)
Its not a connection. Fuel pump has been in the car for a good while. It is an LS with I/H/E. I had the fuel pump in with the b16 i just took out. No problem. I put in an LS drive it for a week and get this CEL. I am going to try seafoam and a refill with some sunoco 94.
I wasn't sure if the PR4 ECU i am using now could see something a chipped P28 didn't? I didn't know the ecu could check fuel pressure.
I guess i didn't word my question good at all. Long Day.
Old Jan 27, 2005 | 03:41 PM
PLAN:B's Avatar
"Code 43 means that your ECU is seeing an irregular voltage reading from your O2 sensor. It is usally because the O2 sensor gets covered in crap because you are running too rich. Swap it out to see if that works."
Got that from a guy from another forum
Old Jan 27, 2005 | 03:58 PM
_jester_'s Avatar
Default Re: CEL #43 with Walbro 255? (PLANBmotorsports)
That would explain why i see it with a code 41. hmm.
Old Jan 27, 2005 | 04:06 PM
JDMlyfestyle's Avatar
Most likely your o2 sensor
Old Jan 28, 2005 | 03:59 AM
_jester_'s Avatar
Default Re: (JDMlyfestyle)
I will find out today! Thanks for the help!
EFn-DirtySouth
19
Apr 5, 2014 04:24 PM
ejfromwestbay
Aug 18, 2010 05:44 PM
HmgLauj69
Dec 23, 2005 05:48 PM
iNetForce
Nov 13, 2005 08:27 PM
Boostless97Lude
Dec 26, 2002 12:04 PM
